| Home > Help Needed / General Tech Chat > 1990ish MG Turbo Dies on acceleration | |||||||
2 Posts Member #: 9769 Junior Member |
22nd Jan, 2012 at 02:48:49pm
Hi - This '90ish MG Turbo dies when I go above 20 mph. comes back when I slow down. I've put in a new carb, with correct spring and needle, a new wastegate, new fuel pump etc.
22nd Jan, 2012 at 02:50:31pm
Fuel pressure reg? |
22nd Jan, 2012 at 04:01:38pm
Unlikely to be fuel pressure reg if it at least runs.
22nd Jan, 2012 at 04:07:17pm
A couple of questions,
25th Jan, 2012 at 09:28:21pm
Thanks for the info. Will check these, I live in Surrey and it's been suggested I should find a local expert to check all that I've done - anyone any ideas? |
26th Jan, 2012 at 07:17:11am
i'd have a really close look at the pipes to the carb ,and the presure regulator ,fold them and squeeze them and see if there are any cracks .also , i'd take the fuel preure regulator apart , its very simple just 4 screws ,and check the diaphragm inside ,is not split ,and the little brass piston is not stuck with debris .
