| Home > Help Needed / General Tech Chat > Gearbox upgrade. | |||||||
82 Posts Member #: 9772 Advanced Member Sheffield |
26th Jan, 2012 at 12:11:12am
Right my final query now that I have almost got my engine built. I need to upgrade my box I'm expecting 140-150bhp and have to my name a standard recon'd mpi box with 4pin minispares diff.
26th Jan, 2012 at 12:20:41am
Hi mate, have a go using the search button as this has been covered before.
26th Jan, 2012 at 12:34:13am
Sorry I'm new to here what should I search? |
26th Jan, 2012 at 12:53:13am
I've had a look and I can't find anything with this exact query and there are hundreds to filter through.
26th Jan, 2012 at 08:16:56am
get straight cut drops. the box will survive if you are gentle with it. try avoid emergency starts where possible.
26th Jan, 2012 at 09:42:48am
I do not intend making any rapid starts. It's for road use hense me wanting to keep the 2.76 final drive.
26th Jan, 2012 at 10:03:53am
email/call minispares. they will tell you what to get On 11th Feb, 2015 robert said:
744 Posts Member #: 7912 Post Whore Australia oi oi oi! |
26th Jan, 2012 at 10:04:41am
if you don't drive it like a dick head it will last.
26th Jan, 2012 at 10:35:35am
Sorry but that is crap advice. Using full available torque in gear with grip is what will break teeth. No one to my knowledge has broken any part of the selector mech, e.g. synchro hubs. Baulk ring problems are down to wear or abuse but although annoying it isn't a show stopper.
![]() 392 Posts Member #: 5702 Senior Member Cornwall |
26th Jan, 2012 at 07:53:42pm
Basically there have been examples of both extremes, people using large amounts of torque with sc drops/helical gearset and vice versa.
26th Jan, 2012 at 09:52:00pm
Well I've never run a turbo before. I have the MRA 1380 turbo set up with 11cc pistons and a head at this spec. a 12g940 cast with 36 inlet valves & std exh valves with uprated double springs (not just std double springs) combustion chambers are std ported to a fairly good standard 11stud.
26th Jan, 2012 at 09:54:31pm
Any suggestions for value for money sc gearsets? |
26th Jan, 2012 at 10:01:29pm
Buy the best you can afford 140 bananas will soon become boring and the boost will get turned up. Try the bestyou can to future proof your build sc box and drops :)
26th Jan, 2012 at 10:09:55pm
On 26th Jan, 2012 Jack2eaton said:
1380 turbo set up with 11cc pistons and a 12g940 combustion chambers are std . A little of topic sorry. But have you worked out your compression ratio ? If the combustion chambers are standard size and you only have 11cc in the pistons you're looking at a compression ratio of about 10.5-1 with a BK450 gasket. That's if the pistons came flush with the block, they'll likely sit a bit below. But you're still looking at a high compression ratio for Turbo use .... Not having a go in any way, just wanted to make sure you were aware. Phil. :) |
26th Jan, 2012 at 11:14:03pm
Ahh I see thanks for that. I haven't bought this head yet i "was meant to pick it up next week. I was told it was standard turbo chambers. I really don't know much about building turbo engines. Only what I have read on here in the last month. Since I decided to go turbo.
27th Jan, 2012 at 12:09:25pm
Turbo phil are you the guy From turbo-mini? |
27th Jan, 2012 at 08:03:51pm
Yes mate. :) |
![]() 478 Posts Member #: 9269 Senior Member Rotherham |
27th Jan, 2012 at 10:48:34pm
Hi Jack if you want to call over some time your welcome and maybe I can help talk you through a few things Edited by dig-mini on 27th Jan, 2012. Craig
