Home > Wanted > Turbo Bits
Mike-998
Member #: 9774
Buckinghamshire
Hi, starting a turbo project, so if you have anything i'll need sitting in the garage i'll happily give you a few bob for it, just pm me with what it is and how much you're looking for.
Bits i'm after:
- Garrett T2 turbo (Working, dont know enought to be able to do a rebuild)
- Actuator
- Dump/Bleed Valve
- Metro Turbo inlet manifold
- Exhaust manifold
- Thin rectangle intercooler (Fit behind grill once coil and dizzy gone)
- Megajolt + Timing wheel, EDIS4 etc...
- Fuel Pump
- Oil Pump and lines
- Fuel Regulator
- Plenum Chamber
- HIF44
- Turbo gaskets for engine and turbo
- Intercooler
- vacuum or any other necessary hoses
Thanks.
jameswildcooper
Member #: 1355
Leicester
I've got a standard turbo manifold?
Also have metro turbo cam if its any use to you?
Mike-998
Member #: 9774
Buckinghamshire
I'd be interested in the cam, have you fite it before? what condition is it in? also, how you you think it would perform on a 998?
jameswildcooper
Member #: 1355
Leicester
Im going Bingley hall if u do want it £25.
Good condition.
Came out a running metro turbo engine.
Think it will b fine a 998 tbh
Edited by jameswildcooper on 28th Jan, 2012.
Ive got a plenum.
Please fit a new iol pump, there not dear to buy
rick
jameswildcooper
Member #: 1355
Leicester
i do also have a metro turbo oil pump but as cossierick has said you probs best off buying a new one.
if you do want mine you can have it for £5?
I've got a bleed valve, can bring it to Bingley tomorrow.
scott the joiner
Member #: 9229
newcastle upon tyne
I've got an oil cooler if interested? With hoses also have an intercooler set up
Mike-998
Member #: 9774
Buckinghamshire
Hi, wont be at bingley i'm afraid. An ihave a 12G295 head allready, needs a bit of cleaning but should be solid.
I'd be interesd in the oil cooler and intercooler? Wh sort of intercooler i it and where did you have it placed on the car? if you want to pm me with your asking price i'll hae aloo sometime tomorow.
Cheers guys.
