Home > Technical Chat > 1300 astra
steve
Member #: 104
Just Registered!
the car is a shit brick, u'll blow the engine putting a turbo on it! i had one and spent ?1000's modifying it and it was crap!!! get a 1600 + and start from there if you want it that badly. *tongue*
oogleman
Member #: 87
thatd be fine but as long as i don't put a bigger engine in it it won't affect my insurance wherther i put a turbo on it or not
Hell, go for nitrous then! This is much easier to fit, and will not require as many mods to the engine that a blower would.
oogleman
Member #: 87
yeah but then i won't get the hiss of the turbo and dump valve
1310turbo
Member #: 41
buy a R5GT turbo then or similar
A-series power! 1972|1310|T3 turbo|Omega pistons|Cantre main strap|Orange clutch diaphragm|AP race plate|Comp pressure plate|Lightened steel flywheel|13-row oil cooler|Vernier duplex timing gear|Phase 2 Piper cam|Green air filter|Hi boost carb needle/spring|2"Stainless exhaust|3"Play mini stainless rear box|Jack Knight s/c 4spd gearbox|Jack Knight s/c drop gears|Silicon coolant hoses|Lumenition HT leads|GAZ lowered height shocks all round|Steel flip-front|Rear safety devices cage|Group 5 arches|6x12 deep dish Minilites|Surf blue/Old english white|
oogleman
Member #: 87
yeah but thats a standard turbo car and so the insurance will b higher on it where as if i simply add a turbo to my 1300 it will not affect my preimium
1310turbo
Member #: 41
i cant see how that works, most insurance companies insist on an engineers report if you have done the conversion your self, and many dont, but i cant believe it wont change the cost of your insurance
oogleman
Member #: 87
well when i phoned my insurance provider they said it would not affect my premium but i would just have to let them know when i had it fitted
