| Home > Help Needed / General Tech Chat > Mirage no longer has supply of T2s. From now on its GT1548 | |||||||
538 Posts Member #: 119 Post Whore Staffordshire or Northamptonshire |
27th Jan, 2012 at 03:25:09pm
Hi all,
Forum Mod ![]() 1927 Posts Member #: 1761 Stalker Bristol |
27th Jan, 2012 at 03:27:03pm
What does the £515 include? |
1492 Posts Member #: 9468 Post Whore Wootton Bassett |
27th Jan, 2012 at 04:33:41pm
will you be making downpipes for these new units? On 10th Mar, 2012 theoneeyedlizard said:
Hypothetically speaking, where would you stick your nozzle? On 22nd Jun, 2012 apbellamy said:
my wife doesn't know what.head is never mind compression ratio. |
27th Jan, 2012 at 04:54:37pm
This unit uses the same stud pattern as the T2 units. The flange positions etc are the same so it fits the standard full manifold kit. Basically a direct swap for the T2 based units.
1226 Posts Member #: 9271 Post Whore Stoke on Trent |
27th Jan, 2012 at 05:00:48pm
i was looking at these last night (used ones) and the gt1549 but that uses the 3 stud pattern flange. one day boost will be mine!
On 10th Mar, 2012 Joe C said:
TBH peple stick it everywhere... and theres merits to each... |
![]() 3756 Posts Member #: 1709 I like granny porn. LONDONSHIRE |
27th Jan, 2012 at 06:08:35pm
On 27th Jan, 2012 wez said:
i was looking at these last night (used ones) and the gt1549 but that uses the 3 stud pattern flange. i run this turbo, i have just used my old R5T hot side, works a treat too... On 2nd Oct, 2009 Vegard said:
I bet my first wank came quicker than your first mini turbo These new modern turbos with their quick spool up time, would make the competition harder. On 15th Aug, 2011 robert said:
phew!!! thank you brett for smashing in my back doors .( not something i imagined writing... EVER) |
![]() 183 Posts Member #: 9548 Advanced Member Manchester |
27th Jan, 2012 at 07:27:24pm
I think I got the last t2 off mirage must say I'm veryimpressed with there service if anyone was unsure of using them http://www.turbominis.co.uk/forums/index.php?p=vt&tid=445578 |
6 Posts Member #: 11058 Junior Member |
6th Feb, 2015 at 10:47:58pm
On 27th Jan, 2012 Mirage said:
This unit uses the same stud pattern as the T2 units. The flange positions etc are the same so it fits the standard full manifold kit. Basically a direct swap for the T2 based units. £515 is for the turbo outright. I'll check if the actuator is included. I do the actuator lever mod on units i supply. I'm interested in the actuator mod that is mentioned here - would be grateful for pics/info - I'm soon to get a GT1548. Cheers. |
