| Home > Help Needed / General Tech Chat > Running in oil | |||||||
63 Posts Member #: 290 Advanced Member Basingstoke, Hampshire |
27th Jan, 2012 at 11:16:55pm
Hey,
Will my project ever be finished !!? hopefully you guys can help !
28th Jan, 2012 at 12:19:45am
i use Graphogen assembly lube for the assembly and cheap mineral oil for running it in, not coma/duckhams ( IMO ) i am using halfruads 20/50 mineral for classics, because i had 6 gallons of the stuff Edited by Brett on 28th Jan, 2012. Yes i moved to the darkside |
28th Jan, 2012 at 01:22:11am
Use an engine assembly lube rather than oil, or can lube and be generous Own the day
1492 Posts Member #: 9468 Post Whore Wootton Bassett |
28th Jan, 2012 at 09:58:32am
so for running in period buy the cheapest oil you can find? I thought youd have to get the expensive stuff because its all dry and its the first run? On 10th Mar, 2012 theoneeyedlizard said:
Hypothetically speaking, where would you stick your nozzle? On 22nd Jun, 2012 apbellamy said:
my wife doesn't know what.head is never mind compression ratio. |
28th Jan, 2012 at 10:25:48am
If you put fancy sinthetic oil in then the ring etc wont bed in properly, but renember never give it the beans with cheap oil in, it for running in only |
461 Posts Member #: 9229 Senior Member newcastle upon tyne |
28th Jan, 2012 at 05:55:44pm
Comma sonic for running in & the same after its run in for me its just a mineral oil but has a good amount of the zzdp aswell |
28th Jan, 2012 at 07:10:29pm
On 28th Jan, 2012 scott the joiner said: u have any problems with 'rocker mayo'
Comma sonic for running in & the same after its run inpfor me its just a mineral oil but has a good amount of the zzdp aswell Yes i moved to the darkside |
28th Jan, 2012 at 07:12:33pm
we never had mayo in the van with comma sonic On 11th Feb, 2015 robert said:
28th Jan, 2012 at 07:28:33pm
28th Jan, 2012 at 07:46:37pm
Sorry double post no I've never had problems in the past so thought I give it another go in the new engine |
30th Jan, 2012 at 07:36:42am
On 28th Jan, 2012 cossierick said:
If you put fancy sinthetic oil in then the ring etc wont bed in properly, but renember never give it the beans with cheap oil in, it for running in only Well as per Brett's post I was going to adopt the hard run in method of which there's info on other threads. So it will be run hard on the cheap oil. I can see how this is better to bed the rings in but it can't do the gearbox much good on such cheap oil ? Guess it not in there that long before its swapped out for better stuff. Also will be having another search later on tonight but anyone got any info on 'Knocking' the cam in ? It's a new build with new cam and followers Ta Will my project ever be finished !!? hopefully you guys can help !
30th Jan, 2012 at 07:57:42am
basically start it up and let it run for 30-40 minutes about 2krpm you can wind in the idle screw to keep the revs up, if you have wide band fitted dont let it run too rich bad for the bores
On 28th Jan, 2012 apbellamy said:
we never had mayo in the van with comma sonic cant remember the exact name of the stuff i used, it was green for years and then they changed it for some regular oil coloured stuff, thats when the problems started Edited by Brett on 30th Jan, 2012. Yes i moved to the darkside |
