| Home > Help Needed / General Tech Chat > Intercooler size | |||||||
43 Posts Member #: 9608 Member Lincolnshire |
28th Jan, 2012 at 01:44:47pm
I've been offered a ic off a calibra for a tenner. It has 2 inch inlet pipes, measures 2.5 inch thick 5.5 wide and10 inch long.I intend to run my 1275 with a gt17 and around 15psi. Sometimes more. Will I get a big gain from using this on the reliability and power scales or should I go bigger? Thanks Ben |
28th Jan, 2012 at 01:51:20pm
sounds a decent size, for that price I'd go with it, try to position it where it will get air, or duct to it,
28th Jan, 2012 at 01:57:00pm
This is the thing, it will fit nicely ion front of the grill opposite side to the rad as it's a pickup without all the plastic ducting in the way. Just didn't no if it was to small to notice it or if the inlets would cause a restriction. Thanks
28th Jan, 2012 at 02:02:16pm
2" inlets are plenty plenty big enough, pretty much any intercooler that you can find will be worth adding.
