Home > General Chat > rockers with ph2 cam?
bennyy
Member #: 9037
Doncaster, yorkshire
Done a search and found mixed reviews, some say use standard, some say 1.3's, some even use 1.5's, so what does everyone recommend? What are peoples experience with them? Are they worth the money over, let's be honest, perfectly good standard rockers?
Cheers lads.
On 15th Mar, 2012 wil_h said:
On 30th Apr, 2012 Brett said:
I'd be tempted to stick with standard mate unless you have money burning a hole in your pocket.
I don't think there will be masses of gain.
I ran 1.5 and it made the engine peaky
liam mini 35
Member #: 9125
Sheffield, South Yorkshire
If hou have a set of 1.5's laying around would you reccomend using them?
The turbo build has finally started
You shit the bed benny?
No, I had the same result as Wolfie. Killed low-down power and made engine peaky.
tadge44
Member #: 2500
Buckinghamshire
Likewise.
They need slightly greater clearances too which makes the engine tappety.
Flame Red
Member #: 6267
I had standard on my engine and always found it really drivable despite 8.1:1 CR. If I'd had more money I would have put 1.3:1 roller rockers on to stop it side loading the valve stems.
scott the joiner
Member #: 9229
newcastle upon tyne
I've got 1.5 on mine but only time will tell as its not fin yet should be done buy the end of the week & to add ian at avr classics (avonbar) said the ph2 was designed for use with 1.5
Edited by scott the joiner on 30th Jan, 2012.
On 30th Jan, 2012 tadge44 said:
Likewise.
Why? The clearence when hot is the same..
the phase 2 valve clerences i always run these at 0.012" inlets and 0.014" exhausts.
1.3 roller rockers are more kinder to the valve guides
Advantage
Member #: 1450
Near Paris - France
Maybe the engine is tappety when cold then ...
Edited by Advantage on 30th Jan, 2012.
Rusty by nature
dig-mini
Member #: 9269
Rotherham
I've had both on mine couldn't tell any diffrance.
Edited by dig-mini on 31st Jan, 2012.
Craig
bennyy
Member #: 9037
Exactly what I thought, cheers lads.
yes it's funny how years ago EVERY one said o yes use the 1.5 rockers, now look at all the people on here that don't! As Turbo Hogster said years ago, us the 1.3 and your engine will live longer!
