| Home > Help Needed / General Tech Chat > Struggling with second gear... | |||||||
31st Jan, 2012 at 06:14:49pm
Trying to get second gear of the third motion shaft and having no success at all.
31st Jan, 2012 at 06:31:01pm
Without special tools, it just takes patience.
1226 Posts Member #: 9271 Post Whore Stoke on Trent |
31st Jan, 2012 at 06:37:42pm
ive just watched this http://www.youtube.com/watch?v=eeQ0OeEL1BY...46fAHTygxYwAAAA
one day boost will be mine!
On 10th Mar, 2012 Joe C said:
TBH peple stick it everywhere... and theres merits to each... |
31st Jan, 2012 at 06:44:33pm
Rod - it's second that has the two plungers. There are 2 holes in the cone bit of the gear about 160 - 170 degrees out.
![]() 2057 Posts Member #: 9252 Post Whore Cleethorpes |
31st Jan, 2012 at 06:47:40pm
sorry Andy for all the trouble Done now needs redoing lol |
31st Jan, 2012 at 06:55:13pm
the holes in the gear only aid the build up iirc, to strip down you need to push the 2 plungers at the same time with a pointy object, and twist the retaining ring slightly to hold the plungers in, then the gear retaining ring should slide up
Edited by Brett on 31st Jan, 2012. Yes i moved to the darkside |
31st Jan, 2012 at 06:58:12pm
the holes in 2nd gear synchro cone are for re assembly.
31st Jan, 2012 at 07:01:18pm
Has to be fixed who ever has the box Curt, don't worry about it.
31st Jan, 2012 at 07:14:51pm
Just looked at some of my old photos... the holes in the gear may help re-assembling - but have nothing to do with dismantling.
Edited by Rod S on 31st Jan, 2012. Schrödinger's cat - so which one am I ??? |
31st Jan, 2012 at 07:53:12pm
Finally got it of!!!!
31st Jan, 2012 at 09:00:08pm
you should have brought it over andy
1st Feb, 2012 at 08:19:18am
