Home > Technical Chat > plenum chamber
MiniDna
Member #: 9660
Hi All,
just a quick question;
I have a 89 automatic 1275 Rover. I am in the proses of turbo charging it. I bought Turbo HIF carby, Turbo manifold and a Plenum chamber.
Initial measurements shows plenum chamber hits the fire wall. Any one did turbo charge auto 1275 and had this problem or did I measure wrong.
scott the joiner
Member #: 9229
newcastle upon tyne
You need a bulk head box to get everything to fit which means you got to cut a big hole & seam weld the box in. There available from many mini spares shops
You probably need to lean the engine forward a bit with an adjustable top steady. When minis changed to HIF type carbs (rather than HS) they moved the engine forward by a few mm.
How much boost are you going to run, not sure an auto will take that much power before it dies...
Did they do a 1275 auto in 89?
I thought all the later autos were 1275. I know someone who had a 'Sprite' that was a 1275 auto. That was an Spi though, so later than 89.
As for the plenum hitting the bulkhead, It will be tight, but as Andy says,
MiniDna
Member #: 9660
Sorry about not giving the full info. Yes you right it is 1275 auto out of a 95 model rover. I am only planing to run about 6 or 7 psi the tops. Plan is to build a rear mount turbo.
We've had this discuaaion before. iirc, the general consensus was that the auto box would be strong enough, but the low (off boost) power might be a problem, something to do with the way the torque converter works. I'm no expert to be honest.
