| Home > Help Needed / General Tech Chat > | |||||||
5th Feb, 2012 at 08:37:17am
If you 13mm doesn't fit on a 1/2" there is something wrong with you 13m, IMO.
On 4th Feb, 2012 dev 11 said:
i have a set of snap on flank drive imperial offset ratchet spanners, and set of snap on flank drive metric, and the 1/2 will not fit on a 13mm. vice cersa tolerance in cheap tools causes damage, iv never had a problem with snap on tools. get the right kit and you can do the job twice as fast. also, i use braided hoses on the servo wez so that just plonks onto the os wheel. http://www.twin-turbo.co.uk
