| Home > Help Needed / General Tech Chat > Electronics - Reverse Light Switches On Side Lights | |||||||
![]() 23 Posts Member #: 3379 Member Staffordshire |
6th Feb, 2012 at 12:49:38pm
Good afternoon. I have a recently installed brand new AutoSparks wiring loom, Pt No. AN134 + AN145 & C 813.
D.I.L.L.I.G.A.F |
6th Feb, 2012 at 04:56:49pm
Check all your earths, especially on the bulkhead and around the boot. On 26th Jan, 2012 Tom Fenton said:
6th Feb, 2012 at 08:12:02pm
Just to check, I know I have an earth at each rear light, obviously battery, then on the o/s inner wing, engine to o/s inner wing, indicators to the body locally and headlights to earth via loom.
D.I.L.L.I.G.A.F |
6th Feb, 2012 at 09:07:27pm
Yep that's it. If it's a freshly painted shell then double check for clean earths. Without going around the loom testing everything out with a multimeter it's hard to say what's going on! On 26th Jan, 2012 Tom Fenton said:
6th Feb, 2012 at 09:21:46pm
Yes it is a freshly painted shell. I shall check all earths when I next get in. Failing that, does anyone live local to Cannock that wouldn't mind coming over and having a check through........?
D.I.L.L.I.G.A.F |
6th Feb, 2012 at 10:25:25pm
sounds like a typical earth problem, there should be an earth on each rear light cluster and then this should connect to the chassis around the fuel tank area Yes i moved to the darkside |
13th Feb, 2012 at 09:25:34pm
Mine did this! it was a bad earth on the bulk head! |
