| Home > Help Needed / General Tech Chat > Running Probs | |||||||
621 Posts Member #: 393 Post Whore Oulton Park |
7th Feb, 2012 at 08:33:50am
Running a non turbo 1275 with a 3 branch manifold, and having problems. The problem is i've been using the metro turbo inlet manifold and i've had to space the carb out more for the rev cable to clear the back of the carb, and i cant quiet work out why its running so bad, whats happenin is you put your foot down and theres no pick up and it seems and backfire quiet alot. I wonderin what the problem could be? What problem would be caused by spacing carb out more? cheers |
7th Feb, 2012 at 09:28:57am
I presume you mean speedo cable?
7th Feb, 2012 at 07:21:07pm
I'm getting a diff inlet cause i was thinkin that it was runnin bad. It is the rev cable cos it has a half moon thing for the cable and it was hitting on the back of the inlet when it moves.
