| Home > Help Needed / General Tech Chat > 4mm bulkhead tube connector | |||||||
7th Feb, 2012 at 04:34:21pm
Anyone any ideas on a UK supplier, like the one in these pictures
Edited by Rod S on 7th Feb, 2012. Schrödinger's cat - so which one am I ??? |
7th Feb, 2012 at 04:51:11pm
have you tried RS components? |
7th Feb, 2012 at 05:44:57pm
You might want to check hobby shops for radio controlled airplane accessories.
7th Feb, 2012 at 06:12:24pm
Rob, I've tried RS, Farnell, all the usual suspects as well as all sorts of instrument suppliers but they were all for push in rigid tubing, not push over soft tubing.
7th Feb, 2012 at 06:25:50pm
How about going to your local air fittings supplier?
7th Feb, 2012 at 06:31:36pm
not quite...........
7th Feb, 2012 at 06:40:46pm
Matty,
7th Feb, 2012 at 06:51:34pm
They sale them on there,
7th Feb, 2012 at 06:57:03pm
you could always get some material and turn some up on the lathe On 11th Feb, 2015 robert said:
976 Posts Member #: 3228 Post Whore North of the Netherlands |
8th Feb, 2012 at 04:06:30pm
I was planning on using Festo fittings:
Dazed and Confused.... |
![]() 580 Posts Member #: 9580 Post Whore Surrey |
8th Feb, 2012 at 04:11:17pm
Eldon James makes them in the states and can be ordered from amazon.com.
8th Feb, 2012 at 05:07:41pm
That would be about 4mm on both sides: http://tubingandfittings.eldonjames.com/it...1624-2-5-2-5-bn? |
8th Feb, 2012 at 06:19:15pm
Thanks all,
8th Feb, 2012 at 06:58:08pm
Rod the push fittings will work with soft tube. What size OD hose have you got? https://www.facebook.com/pages/Fusion-Fabri..._homepage_panel
![]() 2057 Posts Member #: 9252 Post Whore Cleethorpes |
8th Feb, 2012 at 07:09:55pm
try aquatic shops and fittings use them for air lines Done now needs redoing lol |
8th Feb, 2012 at 07:10:27pm
On 8th Feb, 2012 matty said:
Rod the push fittings will work with soft tube. What size OD hose have you got? Matty, it's "standard" 4mm ID silicon tube so the OD is about 8mm. A "push-in" fitting would be enormous
8th Feb, 2012 at 07:28:30pm
Air logic is the only place I can find but they are in the US. There will probably be a minimum order though. Edited by matty on 8th Feb, 2012. https://www.facebook.com/pages/Fusion-Fabri..._homepage_panel
9th Feb, 2012 at 11:40:42am
On 8th Feb, 2012 Rod S said:
Thanks all, Yo-Han, the Festo ones are easy to get over here but work on the OD of semi-rigid tube. I need barbed fittings for the inside of soft tube. Shellspeed/Jean, yes ideal but not on the UK market (well not less than 100 at a time...) I've ordered some brass hexagon bar and dug some of the snow away from the garage door..... Then use 4mm nylon tubing instead of the rubber. Or if you must use rubber in places, push your 4mm ID rubber over the outside of the 4mm OD nylon. Simplez. TBH, I like using the nylon tubing and push fittings. The connections are strong, fast, and very re-usable. Ive a lot of pressure lines done with them now. Much easier than rubber hoses. Edited by stevieturbo on 9th Feb, 2012. 9.85 @ 145mph
9th Feb, 2012 at 12:11:52pm
Stevie, I had thought of that but the semi-rigid stuff isn't really suitable in an engine bay, it goes soft in heat and kinks if you try to put sharp bends in it.
9th Feb, 2012 at 12:21:56pm
Rod, the equipment i work on day to day runs at 180 degrees + and and long as you use the right stuff your fine. Im sure ive got a reel of 6mm od hose in the car that i cut a piece off that your welcome to try? Silicon hose also fits in the push fit connectors. https://www.facebook.com/pages/Fusion-Fabri..._homepage_panel
9th Feb, 2012 at 01:59:21pm
My MAP signal, dump valve, FPR signal etc are all using 4mm nylon tubing. ( well, BOV uses 6mm )
9th Feb, 2012 at 07:56:36pm
Erm, sorry Rod, for getting your thread messed up like this.. Dazed and Confused.... |
