| Home > General Chat > Double Sided Rivets | |||||||
8th Feb, 2012 at 09:54:55am
Chap, Ive looked on the internet for some double sided rivets, as in rivets that have 2 flat sided faces. All I can find is the production of jeans lol
8th Feb, 2012 at 09:59:15am
Weld?
8th Feb, 2012 at 10:04:37am
bond it? or what about male and female socket cap screw thingys |
8th Feb, 2012 at 10:06:40am
Are you after a solid rivet like this?
8th Feb, 2012 at 10:09:52am
Welding is an option but seems a little over kill for what its for. Wils got what I had in mind.
8th Feb, 2012 at 10:29:05am
I think the special tool is called a 'Birmingham Screwdriver' Fastest 998 mini in the world? 13.05 1/4 mile 106mph
8th Feb, 2012 at 10:41:23am
haha, right!
8th Feb, 2012 at 10:52:57am
how many are you buying Mike? I need a few for my doors On 11th Feb, 2015 robert said:
8th Feb, 2012 at 10:54:09am
Not sure yet andy, Ill probably buy a large amount.
8th Feb, 2012 at 10:57:13am
15 should more than cover it. They're just for the tops of my alu door skins. On 11th Feb, 2015 robert said:
8th Feb, 2012 at 11:02:23am
I think the trick is holding the side you're not hammering.
8th Feb, 2012 at 11:03:18am
Ahhh Dibnah, what a guy! 1/4 Mile 14.3secs 96Mph Terminal 10psi of boost.
8th Feb, 2012 at 12:34:57pm
simple ordinary pop rivets.
Edited by Sprocket on 8th Feb, 2012. On 26th Oct, 2004 TurboDave16v said:
8th Feb, 2012 at 12:36:27pm
On 8th Feb, 2012 wil_h said:
I think the special tool is called a 'Birmingham Screwdriver' also known as an Edinburgh socket set On 26th Oct, 2004 TurboDave16v said:
8th Feb, 2012 at 01:07:11pm
What size are you after I have a couple hundred rivets at home. Normally you need a rivet gun and appropriate snap and riveting block. You will need the softest rivet you can buy.
Own the day
8th Feb, 2012 at 01:25:46pm
Mike, get countersunk solid rivets. Countersink both pieces of metal and peen over the rivet into the countersink.
I seriously doubt it! |
8th Feb, 2012 at 01:49:13pm
Thanks for the advice chaps, paul this sounds ideal mate. Ill have to have some practice goes.
8th Feb, 2012 at 02:34:46pm
Get the aluminium rivets - theres steel, copper etc.
8th Feb, 2012 at 02:47:19pm
this was the sort of thing i was looking at, albeit smaller to suit the application
8th Feb, 2012 at 03:57:29pm
Paul do you use a punch or just a hammer to pee them over?
On 8th Feb, 2012 paul wiginton said:
Get the aluminium rivets - theres steel, copper etc. Cut them down to length with side cutters - you only want about 3-4mm protruding to peen down otherwise you'll have a lump. Dont hammer too hard or you'll distort the aluminium that youre joining 1/4 Mile 14.3secs 96Mph Terminal 10psi of boost.
8th Feb, 2012 at 04:30:13pm
I use a punch to get a dome but you want it flat so just a hammer I seriously doubt it! |
1083 Posts Member #: 8932 Post Whore |
8th Feb, 2012 at 05:46:09pm
I had a go at solid rivets when i was back in college making tools. It was steel ones, i don't remember it being too difficult. |
8th Feb, 2012 at 06:46:04pm
A washer behind the rivet? As in place rivet through hole, put washer on the back, use rivet gun. Voila. Edited by Carlzilla on 8th Feb, 2012. On 26th Jan, 2012 Tom Fenton said:
9th Feb, 2012 at 11:45:00am
What exactly are you joining ? spot weld ? or adhesive ? 9.85 @ 145mph
9th Feb, 2012 at 02:03:32pm
http://www.alibaba.com/product-gs/33561555...rivet_bolt.html
