| Home > Help Needed / General Tech Chat > Rear Radius Arm. | |||||||
8th Feb, 2012 at 06:00:34pm
Right
![]() 1342 Posts Member #: 2292 Tool Herne Bay, kent |
8th Feb, 2012 at 06:11:07pm
As far as I'm aware they need reeming in On 27th Apr, 2010 Rick.SPI said:
cant beat a good blowout. |
8th Feb, 2012 at 06:40:54pm
You press the bush into the radius arm then ream the centre of the bush to accept the pin James. What he has is a roller bearing fitted in place of the bush which is bigger than the bush, so it moves about, if I read the OP right. I'm sure Tom Fenton knew of something that may be a solution to your problem but I can't for the life of me think what the stuff is called. He was on about it last in regards to a slack outer race of a wheel bearing in a hub. On 26th Jan, 2012 Tom Fenton said:
8th Feb, 2012 at 06:48:09pm
Carl your on the money, been told on the 16 valve forum that it might be a metro rear arm as they had twin roller bearings, would twin rollers be better? |
8th Feb, 2012 at 07:37:05pm
Its only the bush that wears out, leave the two roller bearings in there they'll be fine I seriously doubt it! |
8th Feb, 2012 at 07:38:14pm
Ive been told to change the arm to get bush and bearing :S I am confused now |
8th Feb, 2012 at 08:56:55pm
I understand what others don't seam to have picked up on
Edited by Sprocket on 8th Feb, 2012. On 26th Oct, 2004 TurboDave16v said:
8th Feb, 2012 at 09:24:35pm
I'm sure I've heard of something where somebody has said there is a radius arm with a bigger track width than the mini version, it's not the metro one is it? Then you'd end up with a strange setup on the rear end. Not sure on this, just something that somebody might be able to clear up.
8th Feb, 2012 at 11:10:46pm
the metro arms have a wider track, but the lever ratio is also different. You'd know if you had one mini and one metro arm. Im not sure if the metro arms had the shock pin stub axles either not to mention them being more square in shape
12th Feb, 2012 at 09:51:57am
Had a look at metro Arm and the Mini arm and my too are Mini Radius arms so its all good but Ill try get hold of a set of radius arms from my mate and have twin rollers and then standard set up and see witch ones are better :) can't lose nothing doing testing |
