| Home > Help Needed / General Tech Chat > Fuel In Dump Valve | |||||||
567 Posts Member #: 102 Post Whore Pennsylvania USA |
10th Feb, 2012 at 08:38:40pm
Hey
1226 Posts Member #: 9271 Post Whore Stoke on Trent |
10th Feb, 2012 at 09:04:31pm
wont the fuel in the dump valve come from the vacuum tube to the inlet manifold? one day boost will be mine!
On 10th Mar, 2012 Joe C said:
TBH peple stick it everywhere... and theres merits to each... |
10th Feb, 2012 at 11:05:53pm
If the DV is mounted very close to the mouth of the carb, it's no surprise some fuel will pass through it.
11th Feb, 2012 at 09:52:58am
Some thing to try is to mount it so any fuel in there can drain back out down the pipe. Best 1/4 mile 13.2 seconds @116 mph
11th Feb, 2012 at 01:32:38pm
I did think it wasn't sealing properly, It's an old diaphragm valve. I have a new one now a piston one and I'm putting it on this weekend. I was just surprised to see fuel in it.
11th Feb, 2012 at 01:39:55pm
uncrew the diagram one and have a look, it should be obvious if it wasnt sealing.
11th Feb, 2012 at 02:12:03pm
Make sure you don't get fuel in the piston one. The seals swell up and tear in no time.
In the 13's at last!.. Just |
11th Feb, 2012 at 05:26:01pm
How do I stop fuel getting in there? |
11th Feb, 2012 at 07:15:58pm
On 11th Feb, 2012 colas said:
How do I stop fuel getting in there? Dont mount the DV so close to the carb. 9.85 @ 145mph
![]() 392 Posts Member #: 5702 Senior Member Cornwall |
11th Feb, 2012 at 10:38:46pm
Where is the signal pipe for the valve connected? There is always going to be some fuel vapour there, I would go with an uprated diaphragm much more resistant to fuel. Also do you have a wideband? I would be concerned if there really was fuel coming out the valve from inside the plenum |
12th Feb, 2012 at 02:23:44pm
The pipe is connected to the inlet manifold just in fron tof the carb. I have a sensor yes. |
