| Home > Help Needed / General Tech Chat > carb running prob 3 branch | |||||||
621 Posts Member #: 393 Post Whore Oulton Park |
11th Feb, 2012 at 04:38:21pm
Got running problem on my mini :( its 1993 carb mini and the carb doesnt have any adjustement just an idle screw. The problem is no power, and its backfiring all the time, when you put choke on it works alot better. Its like its not getting enough fuel, do the three branch manifolds need a different carb? I've had the carb off and inlet 3 or 4 times checking for air leaks but cant find probs with that. Running out of ideas any thought cheers? |
11th Feb, 2012 at 04:48:13pm
has this just happened of have you changed anything? |
![]() 883 Posts Member #: 9774 Post Whore Buckinghamshire |
11th Feb, 2012 at 05:04:46pm
What carb is it? And you say it doesn't have a mixture/adjustment screw so i assume it's not a standard SU one? http://www.turbominis.co.uk/forums/index.p...tid=469104&fr=0 |
1226 Posts Member #: 9271 Post Whore Stoke on Trent |
11th Feb, 2012 at 05:14:32pm
if it is a standard carb it should be a hif model with the mixture screw below the fuel inlet pipe on the side. one day boost will be mine!
On 10th Mar, 2012 Joe C said:
TBH peple stick it everywhere... and theres merits to each... |
11th Feb, 2012 at 05:26:57pm
or a hs carb with a big nob underneath so that you can burn your hand on the exhaust On 11th Feb, 2015 robert said:
11th Feb, 2012 at 10:26:10pm
Doesnt sound good for me, running well before i did anything and i put this three branch manifold on with exhaust straight through, had the metro turbo inlet to start with and swaped it for this normal metro inlet and it still running ruff, i did advance the timing and it run better, but wasnt right. I'll have a look for the screw tomorrow but i'm sure it was not like the ones had before Edited by Zeemax Power on 11th Feb, 2012. |
11th Feb, 2012 at 10:29:58pm
does this set up normally need more fueling, its back firing bad and running with no power like cant do more than 40mph |
11th Feb, 2012 at 10:33:38pm
Possibly, I once fitted what was essentially a stage 1 kit and left the standard needle in, I couldn't get it to do anything i wanted it to do myself and couldnt even drive the thing, changed the needle and had a faf myself and it was a completely different story. Might be worth asking somebody familiar with tuning the a series what needle they recommend.
11th Feb, 2012 at 10:39:14pm
The haynes manual will tell you how to get the idle speed and mixture set up properly, which should help, but for anything other than idle you'll need a different profile needle to supply the correct amount of fuel to the cylinders.
![]() 2057 Posts Member #: 9252 Post Whore Cleethorpes |
12th Feb, 2012 at 09:01:39am
id check to normal causes too like clean plugs and check timing with a light just to make sure there spot on if you have the vizard book it tells you what spring and carb needles to use with what mods. what carb are you using and what size engine are there any other mods il have a look what need and spring you require for you Edited by wng691s clubby on 12th Feb, 2012. Done now needs redoing lol |
12th Feb, 2012 at 10:11:28am
I would find out what needle comes with the stage 1 kit and try one. Audi s4 b5 - 470bhp & 486ft lbs
On 15th Mar, 2012 wil_h said:
12th Feb, 2012 at 10:13:44am
Cheers for the advice, lads i'm going to try swaping a diff carb on today see if that does any good, do the carb gaskets make any odds cause some have bigger middles observly for diff carbs but that wouldn't cause air leaks would it?
12th Feb, 2012 at 10:14:29am
93 is gonna be 1275 with a hif38 unless something's been changed. Is there oil in the dashpot? If something is worth doing, it's worth doing half of. |
12th Feb, 2012 at 08:46:20pm
yes and yes john, didnt get round to the mini today hope to have time tomorrow and then we shall see fingers crossed |
12th Feb, 2012 at 08:55:19pm
Is it a proper 3 into 1 manifold or an lcb? As you may lose too much back pressure if it's a proper race 3 branch. one day boost will be mine!
![]() 825 Posts Member #: 9661 Post Whore Sheffield South Yorkshire GB. |
12th Feb, 2012 at 09:46:47pm
Could the mixture screw still have a anti tamper plug in it.. Alan Main Build
13th Feb, 2012 at 08:45:46pm
i think it has alan, switched carbs tonight and still no joy going to have one last play with with the mixture tomorrow then i'm giving up and putting it back the way it was :( |
13th Feb, 2012 at 08:48:23pm
chucking a big bore exhaust and manifold on will screw the mixture up, On 28th Aug, 2011 Kean said:
14th Feb, 2012 at 02:49:42pm
Bit justice lads, put another carb on and screwed the mixture right in and gave it three turns out and we are back in business,
14th Feb, 2012 at 03:08:57pm
A wideband aem gauge, not cheap but the best thing I ever bought. Edited by bennyy on 14th Feb, 2012. Audi s4 b5 - 470bhp & 486ft lbs
14th Feb, 2012 at 06:44:33pm
What sort damage of over fueling? |
