Home > Help Needed / General Tech Chat > Gearbox issues AGAIN
mw3
Member #: 9590
Derby
Right i have a problem
Having put the sccr gearbox back on the engine and back in the car after quite some time of rebuilding it with new uprated synchro rings and diff i now have another issue.
This time its 4th gear.
When going from 3rd to 4th it simply wont go into 4th! Then it wont go back into 3rd without blipping the throttle. Please tell me this is not the synchros!!
Any help would be of use.
Matt W
On 14th Mar, 2012 mw3 said:
clutch drag.
The pre verto clutch can be tempremental. Might need the pushrod lengthening a little
mw3
Member #: 9590
Derby
I thought it could be drag again, would taking the spring off help any?
Matt W
Not really, i had the same issues with mine, i had to drill and tap the end of the pushrod and put a bolt in. Try popping a small nut between your pushrod and piston to see if that helps.
NickG
Member #: 7912
Australia oi oi oi!
Maybe a good time to move to Roberts RTS?
Why,
Matt has small problem with hid clutch, not with its torque transfer capabilities,
Edited by fastcarl on 11th Feb, 2012.
mw3
Member #: 9590
Derby
Tomorrow im going to have a gander at my clutch setup, i bled it out before i took the car on the run, but perhaps theres still some air in it also. It still felt a bit spongey.
Then ill look into the pushrod.
Are most people still running the standard clutch arm with a grey plate?
Matt W
1380rich
Member #: 9766
Warwickshire
My standard arms been fine for 3 years on a grey mate
Rich
Avon 2010 class c 3rd
nala56
Member #: 9661
Sheffield South Yorkshire GB.
If you had clutch drag it would be hard to get, and would clunk in first and reverse gears, surly would it not.. Alan
Main Build
Upgrade to Turbo
nala56
Member #: 9661
Are you able to select all the gears when the car is stood with engine switched off.. Alan
Main Build
Upgrade to Turbo
eden7842
Member #: 8852
leicestershire
i agree with nala, if its only 3rd and 4th id expect the problem to be somewhere other than the clutch?
mw3
Member #: 9590
Derby
It goes into all the gears when the engine is off.
I think it could be the release arm bending or the hole in the cylinder being in the wrong place allowing too much travel before it starts to build up pressure. The latter being a bit of a long shot.
Going out this afternoon to see if its not just me being a useless dick with the quickshift.
Matt W
Mine never felt right with the quickshift to be honest, too tight and easy to miss gears - no matter how careful I was to do it right.
mw3
Member #: 9590
Derby
Took a bit more slack out, and guess what.... it goes into fourth!
I honestly think it was me being a nob with the quickshift, it does feel like there is very little tolerance with getting it in the gears.
Matt W
Throw the quickshift in the bin,
Chalkie
Member #: 9764
Northamptonshire.
Agree'd with Fastcarl It can destroy the gear box so i have been told
mw3
Member #: 9590
Derby
Wankshift
Matt W
exactly me sentiments, why do we need a quickshift when we all know how fast our wrists can work when we want them to,lol
Wankshift
i have a wankshift in mine and issues with second gear aswell not 4th though that said though ive not used 4th in anger yet *tongue*
i need to get my finger out and finish the inboard shifter
Never had a probelm with mine, and its one of those cheapo wankshifts
it's not a quick shift anyway, its a short shift. If you relax and take your time, it works perfctly well.
shortening the gearstick has the exact same effect
Got to admit, I was put off the idea of fitting one before when i bought a cheapo one, so I sold it, But with an internal gear selector I reckon it would be quite nice, close to the wheel for nice easy changes, sick of having to move my hand like a blur from 2nd to 3rd and sometimes getting it wrong! :/
eden7842
Member #: 8852
leicestershire
ive got a minisport quickshift and it works perfectly, no matter how quick i shift it.
I agree with Sprocket. Mines great. I like the pull up collar for reverse too.
mine worked spot on with my first box, just not on this one
*wink*
