| Home > Help Needed / General Tech Chat > Mini & Metro? | |||||||
12th Feb, 2012 at 03:36:56pm
Right
12th Feb, 2012 at 06:43:38pm
Check to make sure the slave cylinder fits I have a funny feeling the locating pin is in the wrong won't line up. Own the day
12th Feb, 2012 at 07:46:40pm
Oh right If mini one's don't work then ill use metro ones :) |
12th Feb, 2012 at 08:03:18pm
the cylinders are sized to suit the master cylinder and car generally; you may need to do a bit more research to see if they suit your braking system |
12th Feb, 2012 at 08:16:56pm
Ive got the braking Master cylinder the tower style not the tin can style and I'm sure its not a problem as Ill be running 4 pots on the front |
![]() 825 Posts Member #: 9661 Post Whore Sheffield South Yorkshire GB. |
12th Feb, 2012 at 09:57:30pm
If you fit metro ones, they may be to kean locking the back wheels up to soon, if that happens you would have to fit an adjustable regulator to set them up correctly.. Alan Main Build
12th Feb, 2012 at 10:18:02pm
Would it really that bad then? Ive read online the cylinders are same size as Mini cooper S and 84 onwards and shoes are same size its just they are got different adjusters but didn't think it really make that happen to be fair. Steve |
12th Feb, 2012 at 10:25:03pm
If they are the same size as you say, then maybe they will be OK.. Alan Main Build
13th Feb, 2012 at 09:28:14pm
Okay, Ill have to nip Down wilco car masters my mate works there sure we can look through the book and find out and get them ordered :) thank guys |
12th Mar, 2012 at 09:03:32pm
Right right right I've done some Research! Into this :) Involved me getting my hands dirty and pulling a few strings also allot of googling! :) so here is what I have found out.
