Home > Help Needed / General Tech Chat > ive asked this before sorry
Carl
Member #: 95
liverpool-on-sea
right ive now got some 4 point harnesses.b done a search and cant find much.
so wheres the best place to put the rear anchor points top or bottom of rear bulkhead what have most other people done? is the bulkhead stronger at the bottom than the top?
thanks
in the middle *happy*
no kidding either, they want to be in the middle of the seat for a good angle. some nice big plates to spread the load on the back mind.
mines going onto the cage so it doesnt really matter to me!
In the middle really as Iain says. Definately not at the top, as you want the belts angled down slightly to hold you down into the seat in the event of a serious "off".
A lot of people (including me in the past) have mounted the belts in the "corner" between the rear seat back and pan. This can be OK, just make sure the angle between the belt and horizontal is not more than 45 degrees. If it is too steep you can risk breaking the seat in the event of an accident and injuring yourself.
Mounting the belts at the corner also allows you to keep the rear seats in to keep noise down/tidy up the insides. Up to you really, just make sure there is sufficient strenghtening behind the area you choose, I have used both plates and a length of box section and long bolts before now.
t3gav
Member #: 229
Gavin@minispares.com
kent
has anyone got a pic of a 4 point harness and the strengthening required?
Carl
Member #: 95
liverpool-on-sea
cheers guys middle it is then. ive got the plates from minisport to weld in the about 2 1/2 inch squares these should be ok shouldnt they?*smiley*
in my old mini i couldnt pass an mot with harnesses fitted at the base of the rear seat (non rear seat belt model) as they were not a design area for the seat belts to be fitted, i had large spreader plates there but it was a no no
