Home > General Chat > engine paint
bennyy
Member #: 9037
Doncaster, yorkshire
As above, used hammerite in the past, never ran the engine since but from working on/around it has chipped real easy, what does people recommend?
Cheers.
Edit: the engine was cleaned/degreased well, maybe if I took it back to bare metal it may stick better?
Edited by bennyy on 13th Feb, 2012.
On 15th Mar, 2012 wil_h said:
On 30th Apr, 2012 Brett said:
Sam
Member #: 1686
Oxford
Lechler Epoxy followed by 2k.
OMG Robert that's a big one
I've always used the engine enamel - cant recall the make but all the accessory shops tend to have it.
I recall having a discussion with my painter a few years back about painting the block using 'standard' paint; he didn't think it was an issue in principle but had more concern with reaction with the original block enamal
wng691s clubby
Member #: 9252
Cleethorpes
as above
Done now needs redoing lol
bennyy
Member #: 9037
While it is all stripped down I have started taking it back to bare metal with a wire brush attachment
I'll paint it up when its built up.
Machine enamel. Give Somerford Minis a call they do it in brush on or aerosol
bennyy
Member #: 9037
Thanks Paul
blister
Member #: 2590
Croydon
i just bought some Green engine enamel if your interested i am going to have so much left over as i only need a bit,
can be brushed on or mixed with celly thinners
bennyy
Member #: 9037
Thanks for the offer, but its going ever-clean black. Lol
bennyy
Member #: 9037
scott the joiner
Member #: 9229
newcastle upon tyne
Just done mine with halfrauds engine paint its watery while painting on but couple coats seem to have done the trick
bennyy
Member #: 9037
Got half way through taking the paint off and my drill has given up, the build is starting Thursday, running out of time.
bennyy
Member #: 9037
Got some nitromors tonight, I have used ut before with no luck, thought I would give it a 2nd chance, brought the top layer of paint off with no probs, the bottom layer however didn't, but made is 10x easier to come off with a wire brush drill attachment
Would reccomend it to anyone wanting to remove the paint from there block.
metroturbo
Member #: 989
North Yorkshire
I used some red engine paint years ago and it turned bloody salmon pink the first time the engine warmed up. I think it was 'Car Plan' paint.
I used hammerite when I rebuilt my engine. I think I may have done too many coats too quick, as it just wouldn't properly dry while sat in the garage. I had to be careful putting the engine back in the car as the paint was so easy to mark, but once the engine was warmed up it finally dried.
bennyy
Member #: 9037
When I dud mine in hammerite I planned to cure it with a heat gun, but never got round to it and it came off real bad.
I usualy use a decent enamal paint the trick is getting it clean i use swarfreargerer degreaser stuff your meant to dilute it 100:1 with water for general use but neat it disolves oil and grease rather fast (as well as fingers and clothes) after a good rinse off and a thorough dry the paint sticks rather well
it was £7 for a litre at halfrauds last time i bought some
avoid yellow paint like the plague ive used about 5 different brands on my car they all chip so bad
Edited by Brett on 15th Feb, 2012.
bennyy
Member #: 9037
Yeah I think the paint comes in 2nd to the cleanliness off the surface, mine will be bare metal and I'm going to clean the bollocks off it, should be clean enough then.
Benross has always said to use normal non drip household gloss, tbh I've seen a lot of his engines and heads and the finish is very good
Edited by bennyy on 15th Feb, 2012.
Ive used normal gloss paint before and it works fine. I always clean the block down with thinners and a rag before painting until you start to see the shine of the metal.
Ive found spray paints tend to loose there shine once the block has warmed up, but the brush on paints don't. *oh well*
bennyy
Member #: 9037
Cheers matty, the engine is now bare, never realised how many sand inclusionsłdefects they have, engine will be built up then painted, as I have a tendancy to be a bit rough with the engine lol.
