Home > Help Needed / General Tech Chat > how do u tell if a 12g1505a crank is stroked
purpsmini
Member #: 9804
im doing mini engine up i have bought a 1275 nitrated crank with numbers 12g1505a is there any way of telling if its a stroker crank all ive been told its a 1440 stroker with big journals on rods n mains could anyone please help
also can u get straigh cut timing gears
regards tyson
bennyy
Member #: 9037
Doncaster, yorkshire
Timing hears are teeth not gears, like on a push bike. I'm assuming you meant straight cut drop gears
On 15th Mar, 2012 wil_h said:
On 30th Apr, 2012 Brett said:
haimesyboi
Member #: 5702
Cornwall
There was a timing kit with straight cut gears. I don't think they are being produced currently though.
purpsmini
Member #: 9804
bugger love the sound
bennyy
Member #: 9037
Edited by bennyy on 14th Feb, 2012.
wez
Member #: 9271
Stoke on Trent
The big end bearing diameters will be to 's' con rod size if it's been stroked I believe.
one day boost will be mine!
On 10th Mar, 2012 Joe C said:
haimesyboi
Member #: 5702
Cornwall
The timing kit is a pretty special modification, are you sure you don't mean drop gears? ^^^^ they make a horrendously beautiful noise.
agreed but i think were on our own with this thought
Johnny
Member #: 6926
Accrington
sounds like this guy needs to get to some mini shows!!!!! :) :)
Edited by Johnny on 14th Feb, 2012.
jamestar
Member #: 9159
Devon
http://www.slarkraceengineering.co.uk/camshaft_kit.htm
yes thats right
"usually" that are stroked to 84mm
Im in agreement too, im also adding another 2 SC drops to my engine so the it will become a horrendously beautiful unbearable noise. *hehe!*
purpsmini
Member #: 9804
love it i used to have straight cuts in v8 loved noise wanted same for mini but could only ones for gear box which dont make noise at idel
Im sure there was someone on here running timing gears instead of a chain or belt...can't think who though? *oh well*
