| Home > Help Needed / General Tech Chat > lower A+ engine steady | |||||||
744 Posts Member #: 7912 Post Whore Australia oi oi oi! |
14th Feb, 2012 at 11:37:35am
hey lads any one have a photo of these bolted up?
14th Feb, 2012 at 12:01:46pm
If you mean the standard one, there is an adapter plate that bolts to the engine (low down on the gearbox casing) and there is a vertical plate welded inside the "U" section of the front subframe rail. It bolts through a hole in that plate, not the subframe itself.
Edited by Rod S on 14th Feb, 2012. Schrödinger's cat - so which one am I ??? |
14th Feb, 2012 at 12:21:56pm
Photo from a scrap subby out back with steady and adapter plate still attached
15th Feb, 2012 at 11:36:22am
Ah thank you sir! But where does it bolt onto on the engine? I do not want to create any oil leaks haha.. Do you think I need it?? Is it better to have a few steady then just 2 top ones? |
![]() 580 Posts Member #: 9580 Post Whore Surrey |
15th Feb, 2012 at 11:41:08am
gear box studs/bolts that hold the clutch housing to the block/gear box |
15th Feb, 2012 at 06:17:04pm
I spent about half an hour removing mine from the subframe yesterday. lol
