Home > Help Needed / General Tech Chat > Valve Clearances?
Aussie_Dan
Member #: 461
Queensland Australia
Can someone please give me the appropriate valve clearances for sodium filled valves in a T Head.
Also what is the story with the anti run-on valve fitted to the carby? Do I need this and how does it work?
the correct valve clearences dan for a standard turbo is................................
inlet 0.014in (0.35mm)
exhaust 0.016in (0.40mm)
if you chose to use a sportier cam consult the cam grinders spec!
the anti run on valve was a saftey feature for the metro
most of us just blank this off
if its left open this port on the carb the engine will missfire under boost as the float bowl has to be 3 to 4 psi above boost pressure
under certain curcumstances some of us Tee a pipe in from the plenum chamber to this port
so you are getting boost pressure from the plenum
(the same line) which comes from the TOP of the fuel regulator
this is the way to go with out going into detail
This is known as the TEE peice trick
hope i havent confused you
Edited by BENROSS on 1st May, 2005.
Aussie_Dan
Member #: 461
Thats great, thanks. I am on the verge of a maiden voyage, fingers crossed.
