| Home > Help Needed / General Tech Chat > urgent help needed | |||||||
17 Posts Member #: 9804 Member |
15th Feb, 2012 at 08:10:28am
ok the mini is 1000cc atm i just bought new
1492 Posts Member #: 9468 Post Whore Wootton Bassett |
15th Feb, 2012 at 08:53:05am
on my 998 mini I use BPR6ES spark plugs, different to yours? Just something I noticed? On 10th Mar, 2012 theoneeyedlizard said:
Hypothetically speaking, where would you stick your nozzle? On 22nd Jun, 2012 apbellamy said:
my wife doesn't know what.head is never mind compression ratio. |
15th Feb, 2012 at 09:46:49am
cheers ill try anything just tryed 3 times when cold work brilant soon as it get warme drive up street n back cuts out cylinders more ideas could it be electroni dizy faulty |
15th Feb, 2012 at 12:20:23pm
tryed set bp6ey v groved style still stops when warm
![]() 580 Posts Member #: 9580 Post Whore Surrey |
15th Feb, 2012 at 01:40:14pm
You may have a balasted supply to the coil which if memory serves uses 12volts to start the car for extra boost be reverts to an 8v supply once running. This will not supply enough power to a 12v coil once running. * I MAY BE COMPLETLY WRONG AS IT DEPENDS ON WHAT SYSTEM YOUR CAR WAS RUNNING!!!!!!!!!! |
15th Feb, 2012 at 05:19:14pm
Do a process of elimination. Fit the old coil with the new dizzy and try it, then if the problem is still there try the old dizzy with the new coil and try it to see what is wrong.
I seriously doubt it! |
15th Feb, 2012 at 08:28:44pm
On 15th Feb, 2012 purpsmini said:
ok the mini is 1000cc atm i just bought new electronic dizy coil <bosh gt40 non resisted> checked wire has 12 volt leads plugs ngk bp5ey put it all in and ran great turned it off packed up went to start it again and it runs off couple cylinders when reving the motor when it gets in the high rpm somtimes it kicks in and runs great till it reaches idel again when u check for spark on 2 n3 none while running im going to try it when it is cold to see if its only when hot but does anyone have any idea on whats going on its driving me totally nuts Is the coil even suitable for your ignition system ? ie points or electronic ? Did the engine run with a previous coil and no other changes ? 9.85 @ 145mph
15th Feb, 2012 at 08:40:46pm
........ i just bought new electronic dizy..... But what did you just buy ??? If it's new, from where and give us the part number. A little more information would help. EDIT - grammer Edited by Rod S on 15th Feb, 2012. Schrödinger's cat - so which one am I ??? |
15th Feb, 2012 at 09:13:48pm
ok following parts
15th Feb, 2012 at 09:17:38pm
thank u for ur help ill do the process of illimination againg to day
15th Feb, 2012 at 10:39:39pm
When you say plugs 2 and 3 aren't sparking after its been running. What colour are they when you take them out? It could be that the its running a little rich (possibly choke seals) and those 2 plugs are fouling up? https://www.facebook.com/pages/Fusion-Fabri..._homepage_panel
16th Feb, 2012 at 07:20:03am
Are 2 and 3 definately not sparking? or are they just misfiring?
16th Feb, 2012 at 09:55:00am
ok from dead cold runs great once driven down road n come back bout 15 minutes starts droping the 2nd n 3rd cylinder i leave the plugs in the head and connect 2 plugs to the leads after its playing up and thay dont spark wait for it to coll runs great again i sent dizy back as maybe faulty modulator but with points dizzy
17th Feb, 2012 at 03:26:43am
ok everyone id like to thank u for all ur help i had guy come out even thou the coil is a 12volt no resisted running a resister as well as new cap condenser points leads plugs and rebuilt carby now runs
