Home > General Chat > Garage flooring
What does everyone have??
Ive been looking at those foam tiles at costco (think gr4h4m has them) but im not sure how durable they will be, especialy if i have a jack or axel stands in there.
I have got some floor paint at work i could do it with but was trying to find somthing that might be a bit easyer on the knees .lol
I have seen more of the plastic type tiles but there more than id like to spend to be honest.??
Any thaughts
rick
Wile E. Coyote
Member #: 7893
Portsmouth
My floor is just concrete screed finish, and If I am on knees I have an old padded car creeper I rest on with some House Removal blankets, or if I am on my back I am on a newer car creeper,
I use to have carpet underneath and office lay down floor tiles on top but just found they absorbed the moisture and stayed damp/wet, but I suppose this all comes down to the environment and general ambient temperature of you garage.
What is it you at after from the floor?
-Hard wearing
-Comfortable to work on
-Clean
Jamie.
I've got carpet tiles. They do absorb all the spilt stuff, but I like em.
bennyy
Member #: 9037
Doncaster, yorkshire
Concrete with a 2'x2' piece of carpet for kneeling on, and sone old kitchen worktop to sit the engine on, not the best but good enough.
On 15th Mar, 2012 wil_h said:
On 30th Apr, 2012 Brett said:
Adam_R
Member #: 1938
near Dundee
my grandparents old bedroom carpet.
if it gets a bit oily just put down some more
-Hard wearing
-Clean
Lol, yes all three would be good.
dev 11
Member #: 9393
stoke on trent
workshop..concrete, rubber paint and 20x12 piece of cheap red carpet, also with about 20 pieces of test carpet, for kneeling on..
you know when you go carpet shopping they have the foot square cut offs as examples, they sell these for £1...
in the garage jst have bare concrete, that sucks....
graemec
Member #: 1424
Carnforth, Lancs
Vinyl safety flooring (the stuff in supermarket bogs) whch is OK with jacks, axle stands etc and easy to mop/clean and then old gym mats for kneeling/lieing on.
Gym mats in front of the workbench for standing on too - suprising how much less tiring (and warmer) it is to stand on something!
This sort of stuff:
http://www.ebay.co.uk/itm/Vinyl-safety-Flo...=item231951e3ad
Edited by graemec on 16th Feb, 2012.
painted concrete for now but i am going to lay some sheet rubber for some better insulation when i build the new place
Il look into the non slip vinal stuff, could be the answer
Thanks gents
rick
Cooper1999
Member #: 6451
South East Northumberland
Floor paint first (makes wiping up oil easier):
Rubber matting in front of the work bench (much more comfortable to stand on), with carpet off cuts from when the house was redone and theshell was sat on the floor:
When (if!) its on its wheels, the carpet will be going.
As already mentioned, it soaks up any spillage, and I wouldn't do any welding obviously (if I end up welding fibreglass things have got a bit drastic).
I do have some carpet squares which I move around when I need to move things from one place to another - I seem to remember these being quite cheap.
In the shed I've got the off cuts of lino from the bathroom, it's good for the shed but I wouldn't use the jack on it, or use axle stands.
nick1275
Member #: 1615
Ferndown, Dorset
at my parents i painted the floor then carpet which was fine, just had another bit at the front of the car to soak up the oily bits.
my garage now has floor paint then these
http://www.eco-tile.net/ecotile/loose-lay-tile-product/
i work as a floorlayer, so we just happened to have enough 'damaged' ones left over on a job. they take oil, jacks, axle stands brake fluid heavy things getting dropped etc
On 1st Mar, 2009 MikeRace said:
Hmmm weberyyy
On 21st Apr, 2009 madcatminis said:
I hope she's got knickers on or you'll have a funny runny mark on your bonnet. Quite like what a snail leaves behind.
G13B
Member #: 1376
Epoxy is nice strong too
They do look nice nick but not a £500 to do the garage lol.
Think i might just paint the floor for the moment and dig the carpet off cuts out of the loft.
Dr. jinG
Member #: 368
Roseville, CA (USA)
I epoxied my floor. Definitely makes cleaning up any type of liquid a much easier proposition!
1967 Cooper 's' Turbo build @ www.drjing.com
My garage was carpeted when we moved in. Took it up eventually. Got bored of it setting on fire when welding and soaking up every drip of oil. Was cold and damp in the winder...
Also the pattern was horrid. Clashed with the upside down skip...
bennyy
Member #: 9037
A bit of topic from the op but what do you paint the floor with? Mine is oily and tatty and could do with a spruce up.
mini93
Member #: 2017
Warwick.
I looked on eBay the other day, searched garage floor paint and there's quite alot on there, not massively expensive either
David.
Floor paint isn't that expensive really. Mine has lasted 5yr of quite heavy use at times, it is getting ready for doing again now really.
I'm gonna paint mine soon.
Anyone recommend a specific floor paint? Also should I PVA it first?
Definitely PVA first. 50-50% mix PVA and water mixed, then just get a cheap broom and sweep it out.
Scruffy
Member #: 328
Seaford Rise, South Australia
Epoxy all the way Rick
On 5th Sep, 2011 Vegard said:
G13B
Member #: 1376
I used Cold degreeser and then applied 2-3 Fiats of epoxi With à pretty long haired roller, wasn't overly pedantic just whip it on, looks ace and garage is so much brighter
