Home > Technical Chat > Bushed idler gear
Asphalt
Member #: 1027
Germini, black forrest
Hi!
Winter break, time for silly thoughts... We've all seen harrys pressure fed idler gear. Now - would it make sense to combine that with a bush instead of a roller bearing? I guess two bushes would need to be very carefull reamed in line.
But basically, would it make sense to support the idler gear journals like crank journals? Plus fixed thrust bearings, like on the crank?
Just some thoughts to keep me occupied... *happy*
Jan
[X] nail here for new monitor
ntm1275
Member #: 9395
I've not seen it, do you have a link - I've searched this forum but can't find anything
Asphalt
Member #: 1027
Here you go: http://minifreunde.at/harry/links/oilpressure.htm
The details of Harry's mod has come up before and it has allways surprised me that it works.
As a general rule, roller bearings don't like to be pressure fed, especially not needle rollers or high speed bearings - if they are over-fed with oil, the rollers stop rolling and start sliding.
Especially true of needle rollers because their small diameter means they have to revolve very fast and they usually don't have a cage so rub against each other which means they don't like to roll in the first place.
But it is a general rule so maybe what Harry is seeing is improvement on the thrust washers wear rate is covering up any wear on the needles.
So, back to the question, if I was doing a pressure fed setup, I would use plain bearings in preference.
But it's only theory unless someone tries it.....
Asphalt
Member #: 1027
Hmmmm... Maybe the tight packing of needles & pressurised oil outweight one anothers negative effects?
The idler bearings are not pressure fed, just gravity fed in the normal way. It's only the thrust bearings that are pressure fed.
