| Home > Technical Chat > Transmission Input Bearing Advice Needed | |||||||
265 Posts Member #: 368 Senior Member Roseville, CA (USA) |
16th Feb, 2012 at 07:26:00am
A company rebuilt my transmission several years ago, and I'm now finally at the point of having mated it to the block. Upon attempting to fit the clutch housing over the gears, I noted some fitment issues.
16th Feb, 2012 at 07:36:26am
You need to have a complete bearing - the bearing inner race which is on the input shaft and the outer which is pressed into the housing. They are a matched set and so vary in size between models and suppliers I seriously doubt it! |
16th Feb, 2012 at 07:59:15am
I wouldn't worry about using the turbo bearing, the std one copes quite fine in my experience |
16th Feb, 2012 at 05:23:21pm
Thank you both for your input! I'll trade out my buggered housing for a better A+ model, then.
16th Feb, 2012 at 05:31:27pm
If you cannot find it you HAVE to go the whole bearing route I seriously doubt it! |
16th Feb, 2012 at 09:49:59pm
Thanks, Paul. Assuming I can't find it, would you recommend accepting the trade and going with the standard bearing, or trying to find the proper turbo bearing (which is apparently difficult to find in the USA) to use with my existing housing?
Edited by Dr. jinG on 17th Feb, 2012. **************************************
