Home > Beginners Tech > How much is too much?
Mike-998
Member #: 9774
Buckinghamshire
Just had the feeler gauges out on the T2, looking at the clearances between the impellers and the housing;
Compressor:
Min Clearance: 10
Max Clearance: 30
Turbine:
Min Clearance: 20
Max Clearance: 40
Side to side movement was pretty much nothing, or at least, nothing measurable.
Is this okay to run? Or will it need a rebuild?
If you have play down the length of the shaft it'll most likely need a rebuild unless it's the tiniest of amounts, that's the impression I've always been under, best to be safe than sorry!
A little side to side is okay, the oil pressure takes that up when it's running.
Mike-998
Member #: 9774
Buckinghamshire
Thanks, the play down the shaft is almost nothing at all, but as you say, I'd rather be safe than sorry, so i'll look into a rebuild kit.
