| Home > Help Needed / General Tech Chat > weber carb for boost | |||||||
326 Posts Member #: 1323 Senior Member |
17th Feb, 2012 at 06:06:30pm
Can anyone suggest a downdraught weber for a low boosted [5-8psi] 1200cc motor
17th Feb, 2012 at 07:19:47pm
You need to search, this has been discussed several times.
17th Feb, 2012 at 07:38:20pm
I did search - but can't find [ I don't get much joy with my searches ?]
17th Feb, 2012 at 07:47:09pm
somthing like this should be not to hard to convert I think.
17th Feb, 2012 at 07:54:53pm
http://www.scuderiatopolino.com/generalcat...d.php?id_area=6 On 28th Aug, 2011 Kean said:
18th Feb, 2012 at 05:29:45pm
On 17th Feb, 2012 Joe C said:
somthing like this should be not to hard to convert I think. http://www.ebay.co.uk/itm/Ikov-Twin-Choke-...=item2ebb3690fc the trouble you will have is most downdrafts the buterflys open one after the other, so you will get unequal flow on that manifold. Thanks Joe Still can't get any joy with the search feature Anyone have any experience Could I get away with boost referencing the float chamber and leaving the rest of the Weber standard ? I'm not planning on more than about 8psi boost max |
18th Feb, 2012 at 05:34:44pm
you might get a bit of fuel leakage from the throttle spindles, i'd try it and see...
18th Feb, 2012 at 06:59:28pm
the trouble you will have is most downdrafts the buterflys open one after the other, so you will get unequal flow on that manifold. have checked - its a normal twin choke manifold with common chamber feeding each port |
