| Home > Help Needed / General Tech Chat > distance between head and piston | |||||||
46 Posts Member #: 351 Member |
2nd May, 2005 at 10:45:33am
hello, French turbocharged 998cc |
2nd May, 2005 at 11:00:13am
Which cam and rockers are you using?
2nd May, 2005 at 12:05:31pm
Cam is avonbar phase 2 and rockers are standard.
2nd May, 2005 at 01:24:39pm
AT full lift they will, because the valve lift is bigger on aftermarket cams (normally) Also, 1,5 rockers will lift the valves 15 per cent higher than 1,3 rockers.
4th May, 2005 at 12:12:46pm
thank a lot.
982 Posts Member #: 97 Post Whore Near Daventry, midlands |
4th May, 2005 at 04:12:03pm
vegard was the 1191cc engine an overbore'd 1071? i forget the cc's nowerdays, but if it was a overbore i'd be curious as to what you did about the head gasket with the pistons protruding above the block surface?
Edited by andeh on 4th May, 2005. I've seen the future and tbh its Pie
5th May, 2005 at 01:04:10pm
It's a SA 1071 cranks which has got 70,2mm stroke, and 73,5 bore. We just used a milled down A block. The head gasket is bigger than 73,5mm, so no problems there. On 13th Jul, 2012 Ben H said:
5th May, 2005 at 02:21:36pm
interesting! i was informed that the normal head gasket overhangs the cylinders on a 73.5 bore? Im presuming you used a different head gasket? I've seen the future and tbh its Pie
5th May, 2005 at 05:29:24pm
