Home > General Chat > Tightening Hub Nut
svrdaniels
Member #: 3600
Gateshead
The Haynes manual describes the temporary use of a large plain washer during the process of tightening up the hub nut. I am new to the disk bake setup having had drums previously. Just wondering whether people follow this method or simply don't bother.
If it is necessary, where can I purchase such a washer from?
Thanks
Simon
I do have one of those, but most of the time I cant find it so dont bother with it,
just torque it up undo it and turque it up again, then check it after a few miles.
bennyy
Member #: 9037
Doncaster, yorkshire
I have never bothered and has been fine
On 15th Mar, 2012 wil_h said:
On 30th Apr, 2012 Brett said:
I see no need to use one of those washers
I never even new such thing existed! *hehe!*
I knew about them, wanted to use one but couldn't find one so I didn't bother and mine have been fine
ntm1275
Member #: 9395
I think the reason for the washer is so that you can pull everything in to the correct position before putting the split tapered washer on
I have seen the split tapered washer lock up before everything has seated properly, meaning the bearings are loose
Edited by ntm1275 on 18th Feb, 2012.
If everything is fitted correctly it all should push together by hand without the need for pre - tightening
never even knew about them, torque and re torque is all i do
svrdaniels
Member #: 3600
Gateshead
Thanks for the advice, I shall not bother with one of the washers
This is spot on the reason for the procedure involving the flat washer.
However for anyone with half an ounce of common sense it's pretty obvious when all is well or not as the case may be.
Just use your free hand, push the driveshaft firmly toward you, whilst tightening up with a ratchet before torquing up is my method of doing it.
like most on here, i don't bother with them, or knew about them!
Mr Joshua
Member #: 1954
Luton Bedfordshire
I use a dead blow hammer to drive the flange onto the splines as I tighten the nut finger tight.
Never heard of that washer.
Own the day
Jason G
Member #: 1459
En-suite user
Braintree, Essex
Snap, never heard of the washer method.
On 19th Jan, 2010 wil_h said:
Just tighten the bitch tight as fook!
