| Home > Beginners Tech > Top end fuel starvation | |||||||
27 Posts Member #: 2317 Member Newport South Wales |
18th Feb, 2012 at 09:50:02pm
My problem is the engine will pull really well up to 4000 rpm and then it develops a huge flat spot, actually its more like a hole than a flat spot. Engine is 1380 twin hif 44 carbs, this set has worked perfectly in the past and was rolling roaded by Neil Slark @ 110 BHP. The issue started after the carbs were stripped to cure an over fueling issue caused by the choke seal failing. I fitted service kits in both carbs, when you drive the car and monitor the fuel air mixture with an oxygen sensor it shows good fueling up to 4000 rpm and then it suddenly shoots up to 20+ AFR. I have fitted richer needles changing BAM`s for BAP`s but made little difference. I feel that I am missing something obvious here but cannot put my finger on it.
18th Feb, 2012 at 10:41:32pm
Pump and hoses ok? I run a supercharger and I don't care the TB is on the wrong side.
19th Feb, 2012 at 11:50:45am
loose needle maybe ?
