Home > Help Needed / General Tech Chat > Rust in bores
Asphalt
Member #: 1027
Germini, black forrest
Hi!
I've examined all my 1275cc blocks I have - the only with bores that look like they are usable is +.20 block. No vertical grooves, no 'steps' in the bores and pistons are also OK (ring gaps all OK ande within tolerance).
Only one problem: number two cylinder had rust on top of the bore. There's a horizontal mark in the bore after honing and the cylinderwall is colored dark. The mark is feelable by fingernail. It's maybe 2mm below the 1st ring on TDC.
Question: will this be usable?? It's not going to be a high performance engine. MG cam, stock large valve head - and that's it. Quick & dirty low-budget racing.
Jan
[X] nail here for new monitor
Deliver it to a machine shop!
tadge44
Member #: 2500
Buckinghamshire
I have the advantage of being able to change engines more easily than in a mini, so I would definitely use the that block and see what happens. If it smokes or rattles you are no worse off except that you will need to strip before following Vegards suggestion.
as above,
Clean it up with a bit of wet/dry and wd40 or oil and see what it's like.
It would need to be pretty severe rust to make it worth worrying about, which would leave obvious pitting.
Or a quick DIY hone of the bore to clean it off.
Asphalt
Member #: 1027
Will do that. Thanks! :)
Jan
Put a bog brush in the drill and run it up and down the bore
Asphalt
Member #: 1027
After some bog brush (what!? *happy*) action... No, after some carefull honing:
Jan
Edited by Asphalt on 21st Feb, 2012.
Chalkie
Member #: 9764
Northamptonshire.
only looks like surface rust :) just clean with some Emare cloth and run oil down them while doing ti and shoild be fine but don't hold me to that
Asphalt
Member #: 1027
There's a slight horiontal groove, looks like a ring stuck to the wall and left a mark. But since it's the best I have - I'll give it a try... :)
