Home > Help Needed / General Tech Chat > mirage kit
tonyl3
Member #: 9551
nuneaton
ive got a mirage kit and just fitted the down pipe but ive found its hitting the drive shaft what am i doin wrong has anyone had this problem thanks
alaskanow0
Member #: 8466
Mansfield
I found mine hit the subframe, so had to cut and weld it.
I thought that he'd fixed this with the mk2.
Best way is to make a bracket on th ebottom of the gearbox to hold it off the pot joint.
tonyl3
Member #: 9551
nuneaton
was there a problem with the kit then
Originally there was a problem, most people sorted it by cutting and rewelding the downpipe in the correct position. Im sure I read that the jigs had been altered now though.
This may help.
http://www.turbominis.co.uk/forums/index.php?p=vt&tid=214707
