Home > Help Needed / General Tech Chat > Silicon / Aluminium Bends
Ben H
Member #: 184
Melton Mowbray, Pie Country
I have been trying to pipe up my intercooler and to do a nice job I need some 30 degree and 60 degree bends. I have found some expensive 60 degree bends (merlin) but no others.
Does anybody know where I can get either aluminium bends or silicon bends at these angles. All the pipes are around 60mm by the way.
Ben
http://www.twin-turbo.co.uk
shellspeed
Member #: 9580
Surrey
http://stores.ebay.co.uk/dphsiliconehose
http://www.ebay.co.uk/sch/cougarperformanc...=1&_from=&_ipg=
used both and happy with the stuff
bennyy
Member #: 9037
Doncaster, yorkshire
I would go to an exhaust place get them bent up.
On 15th Mar, 2012 wil_h said:
On 30th Apr, 2012 Brett said:
t@z
Member #: 452
Chester, UK
i used apmotorstore for all mine. i dont know what there prices are like but they didnt seem expensive and delivery is insanely fast!
http://www.apmotorstore.co.uk/
www.twitter.com/lilpinkiy
I've made up templates in 2" steel pipe and am taking them to a local exhaust fabricator to bend up the final job
Ben H
Member #: 184
It's a shame that all the normal companies (some listed above) and all the others I have looked at only do 45, 90, 135 and 180 bends. Nothing in between. Getting someone to make some ally ones seems the best option if i want it to look nice.
Will a 45 not have enough give in it to do the job?
jamie@thefatgarage
Member #: 9345
Sheffield
You can turn a 90 mandrel bend into a 60 by cutting it at the right bit on the bend and adding a straight bit, then grind the weld flat if you want it to look pretty.
Ben H
Member #: 184
I have looked at it again now and seem to have my angles slightly wrong so I will have another go at guessing what I need tonight.
I think that a 45 might do it, but it is never ideal to streach them too much.
If you rotate the 45deg one, you can easily achieve a 60deg bend.
If that makes sense?
bennyy
Member #: 9037
If you cut the edge off at an angle it will alter the angle of the bend also, I had to do this on mine.
Ben H
Member #: 184
It seems that the answer to my question is NO. Nobody off the shelf supplies 60 and 30 degree bends for what I want.
Thanks for all the advice above. I know that I can get it connected up and running with all sorts of weird and wonderful techniques, but I know how I want it to look so I am trying to do it right.
http://racebikebitz.com/Samco-Sport-Silico...gree-Elbow-60mm
60 Degree Silicone there if it's of any use!
I found the same link as Carl, but appears to be more than Merlin are charging.
Ben H
Member #: 184
The update is that I have turned my intercooler round the other way and now two 45s will work perfect and the other side works with a 90. So all sorted.
That, Ben, is fucking genius. I can't believe it's taken this long to think of it!
How long were you standing and staring at it before the nugget of an idea formed?
Ben H
Member #: 184
Bloody ages. I need to cut out some fibreglass and re-glass in the intercooler, but that won't take long tonight.
Hurrah!
eden7842
Member #: 8852
leicestershire
Have u tried deamon tweeks?
Mr Joshua
Member #: 1954
Luton Bedfordshire
SFS hoses in Luton
Own the day
Ben H
Member #: 184
Just ordered everything I need for the intercooler and radiator. Including a bit of ally pipe it came to over 130 notes. Still it should look god and it it quarter of the price of samco stuff. It should look nice anyway.
