Home > General Chat > Working a gearbox casting
Star Mag
Member #: 375
Leicestershire
Well I have sourced a couple of good gearbox casings that I going to build my new gearset into. I'm looking to work the inside of casing to remove any casting marks and possible stress raisers. If this will be successful I'm not sure but it's got to be worth ago!
What's the best tools for this? Currently using a air die grinder and some carbide burrs. These have a tendency to clog up. What's best to give a good finish.
Cheers Ron
You could try Roloc sanding discs on an angle air die grinder.
Carbide burrs work really well, just put a few drops of oil on it every now and again and the swarf doesn't clog. *wink*
Star Mag
Member #: 375
Leicestershire
I will give them both a try. I have only given it a half hearted try :)
The pile of new parts for the car gets bigger just been lacking time recently!
Ron
Rub soap on the aluminium and the burr to help prevent clogging. As above Roloc disks are excellent and finish off with a 120 grit flap wheel.
I tried some roloc disks on a steel panel the other day. The results where surprisingly good.
I get through hundreds of them
I only welded up the left hand drive wiper holes in the valance and went through 4 stripping paint and finishing of grinding the welds...
Ive been looking at doing this to mine. Has anyone got any pics of the finished product?
Here ya go Matty, you can only see a bit of it though
Why not get some burrs made for aluminium? *Confused*
Star Mag
Member #: 375
Leicestershire
That's some motivation Paul. Some hours have gone into that :) Cheers for the feed back. I've used rolocs at work but they are more like scotch pads for cleaning gasket faces etc.
Theyre good aswell, its surprising how soft the casing is
Cheers Paul, thats good enough to get the idea.
Chalkie
Member #: 9764
Northamptonshire.
Aren't some mark 1 Casting Magnesuim though?
allegedly very very early ones, ods on you'll never see one.
Is that roloc stuff a bit like the harsh side on a washing up sponge and sort of looks like a pond filter and used for paint prep?
If it is, I used that with some gt85 to clean up my block face from surface rust and it worked wonders!
the rolocs have all sorts of different finishes on them. I bought a bag with several hundred disks and a few heads for about £30 from egay.
Mr Joshua
Member #: 1954
Luton Bedfordshire
There are a couple of teeth profiles for carbide burrs, I would recommend the chip breaker profile of teeth to minimise clogging.
Own the day
impressive Paul and good advice. Good luck with this Ron, I hope you manage it ok.
Star Mag
Member #: 375
Leicestershire
Just ordered a load of rolocs in different grades so will get on with this over the weekend. maybe wasted time if I break the box on its first use :)
You wont break the box. I ground over a kilo out of mine
Consider, if you were not that bothered about the weight saving, is there any benifit gained from the effort, other than the weight saving?
I've just got my gear case back from the machine shop after having a couple of the casting core joints welded on the center web since they left a nice area for a crack to propigate. Do I spend x number of hours sanding fuck out of th casing for little gain?
I began mine so my Salisbury would fit, but then carried on. Ive heard of lots of people stress relieving the casing and block
Is there anyone that has broke the casing, except Fast Carl's twini?
