| Home > Help Needed / General Tech Chat > how to link megajolt to the computer? | |||||||
23rd Feb, 2012 at 11:28:10am
good morning. i am not the best on computers so please bear with me.
23rd Feb, 2012 at 11:37:08am
EDIT - has the MJ got a genuine USB connection or a serial connection that needs a USB/serial adapter. (end EDIT)
Edited by Rod S on 23rd Feb, 2012. Schrödinger's cat - so which one am I ??? |
23rd Feb, 2012 at 12:03:03pm
thanks for the input rod. please bear with me as im useless at anthing computer based. so i have now checked the paperwork and have downloaded what i need to from the web address given. this has saved as a 'zipped' file. i have tried plugging the computer back into the car but its the same, so it seems that im still not there with this yet? what else do i need to do? thanks for your patience with this, dan
![]() 2054 Posts Member #: 452 Post Whore Chester, UK |
23rd Feb, 2012 at 12:18:08pm
hi mate,
Edited by t@z on 23rd Feb, 2012. |
23rd Feb, 2012 at 12:41:17pm
On 23rd Feb, 2012 welshdan said:
looking back at when i ordered this, the cable that the mj came with is a RJ-11 to RS232 computer cable if that mean anything, thanks again, dan The RJ11 is usually just a compact connector for standard serial (my TechEdge widebands use that connector too) and if the cable ends in a DB9 connector ( flat sided oval, 4 pins top, 5 pins bottom) you are presumably then plugging this into your USB/serial adapter ??? If so, it is still the drivers for the USB/serial adapter that are needed. If you downloaded them as a zip file, unzip it (just double clicking on the folder should unzip it and open it). Save all the unzipped files somewhere obvious. From then on there are two ways, the easiest way, if it works, is to plug the USB/serial adapter into the laptop and it should detect it and ask for drivers. if it does, tell it where you unzipped them to. If it doesn't, they may already be installed - go to Control Panel, System, Hardware, Device Manager, Ports (COM and LPT). If the drivers are installed correctly it will be listed as a "USB-SERIAL (something)" then you can double click on it and then Port Settings, then Advanced, and allocate a COM port number....... (those instructions are for XP, it may be slightly different in W7 etc.) Yes, USB/serial adapters are a right pain in the....... Schrödinger's cat - so which one am I ??? |
23rd Feb, 2012 at 12:48:14pm
ok i think that this is installed properly. its installed in device manager etc as com3, i have changed the specifications as per the instructions that came with the megajolt. still when connected to the mj ecu, with ign on, and mj software open the bar across the bottom still states that it is unable to connect to port. this is the most difficult part of the mj install. i am using windows 7, is the consensus that this just wont work and i will have to buy a different computer? cheers, dan |
23rd Feb, 2012 at 01:00:10pm
also, yes, the lead that came with the megajolt i have plugged into the usb adaptor. i really am at a loss with this now - i thought it would have been simply a case of plugging the ecu into the computer but this obviously is not the case |
23rd Feb, 2012 at 01:26:20pm
Try going back into Device Manager and re-setting the COM port number to 5, or 6, or 7, or 8, or 9 and obviously telling MJ which one you have selected. Unplug the USB/serial adapter for a few seconds after making the change for all the settings to take effect then plug it back in and go to Device Manager to make sure.
23rd Feb, 2012 at 01:40:34pm
welshdan if you are still struggling later i will attempt to try this later on my laptop and so screenshots and post them for you as i need to try this com port stuff anyway to get mine to work. but might not be till late. Edited by t@z on 23rd Feb, 2012. |
23rd Feb, 2012 at 02:18:34pm
ok, i have changed the number to com7. the computer states that the hardware is working properly, and the hardware is up to date. it also appears in the task manager when selected. i have changed the settings as per the mj specified settings. so as far as i can see this is intalled peoperly so should be working now? also i bought this from trigger wheels, i have emailed them asking for advice. however i would say that if there was one of these cables that worked then it would be one supplied by them for this use. so i cant see that i would be needing to try different usb adaptors as if this was a regular problem for this aplication surely trigger wheels wouldnt be selling them? if anyone else can come up with anything else that would be great. thanks for the input. taz if you get chance to do that i would apreciate it very much, thanks again |
23rd Feb, 2012 at 03:12:35pm
ok i have sortd this out. trigger wheels emailed me back within half an hour and forwarded a troubleshooting guide to me. i overlooked the fact that i need to select the drive from the magajolt interface from the top menu. anyway it is now sorted, i am really glad that this is now ok. cheers rod and taz(if you need a look at the troubleshooting guide if you have problems with yours drop me a line), thanks again for the input with this, cheers dan |
23rd Feb, 2012 at 03:40:59pm
dan you on about in the calibration where you select when its to pick up the reading and drop down menu with the MAP/TPS option?
23rd Feb, 2012 at 06:02:39pm
Dan, I would like to see that troubleshooting guide too, please.
