| Home > Help Needed / General Tech Chat > Stiffening front suspension(metty) | |||||||
2nd May, 2005 at 09:20:03pm
This is on a hydro gas metty,pete said something about rubber shockmounts but he ain't been on here for a while. Edited by Dangerous on 2nd May, 2005.
2nd May, 2005 at 09:24:30pm
No, I think from vague distant memory, you use bump stops off the back of an MGB, these are quite a tall, very progressive type of bump stop, so effectively stiffen the suspension up. You set the ride height so as to be _just_ off the bump stops, so as soon as it moves it settles onto the stops and then compresses them.
Edited by Tom Fenton on 2nd May, 2005.
2nd May, 2005 at 09:30:36pm
Yeah mgb was mentioned somewhere,but the bump stops got cut off to fit the shocks,But I see in haynes book metty turbo had bumpstops fitted to top arm and the contact area on the hydragas cover plate where as normal is the other way round
