Home > Help Needed / General Tech Chat > where is the edis unit ?
oliver122
Member #: 9625
hey guys ive been to the scrappy's today , have a look around some of the cars they have in , ive found the coil pack , and ive found the sensor , but couldn't find the edis , i searched all round the engine bay and couldn't see it , does anyone have and idea where they are ?
cheers
ollie
What year car, since the EDIS unit is an old technology
oliver122
Member #: 9625
looked in escorts , sierras could seee everything else , just not the edis
Chalkie
Member #: 9764
Northamptonshire.
its normally on the bulk head on Fiestas near where the pipe comes off for it, it could have been raided before it dose happen :( Ive got the senor all I have found so far
passenger side inner wing on escorts
oliver122
Member #: 9625
ive been having alook on the tinterweb and come across this : http://www.msextra.com/doc/ms1extra/MS_Ext....htm#findedisEu
when you say inner wing to u mean like in the engine bay or on the other side like the wheel arch ?
engine bay side
NickG
Member #: 7912
Australia oi oi oi!
you can buy them from ebay.
hit ebay worldwide and the usa one will pop up..
might cost a bit more with importing? you get hit with import tax??
this is where i got mine from; its mounted on a metal bracket behind the headlanp area; If you strip out the wiring carefully, there should be enough to fit in the mini without cutting the signal wires etc
