Home > Help Needed / General Tech Chat > Pre A+ engine
clubby_turbo
Member #: 403
sydney Australia
ok, this is going to sound a bit strange but im halfway through building my 998 turbo engine but i never really knew if it was an A+ engine or not, i dont know all that much when it comes to engine models but after reading the "mini magazine" yesterday i work'd out it must be pre A+.............. should i be concerned? Should a Pre A+ engine be ok for turboing? Also what are the differences between the two engines performance and strength wize?
Thanks. Chris
998 turbo
Nothing.... The only practical difference, is that A+ rod bolt are press type fit, whereas the A uses circlips
clubby_turbo
Member #: 403
sydney Australia
awsome, thats good 2 hear, thanks
998 turbo
Hey Vegard, Isn't it only some A+998 use press-fit? I recall the majority used circlips???
All the A+ 998's I have ever stripped down used press fit gudgeon pins?
I thought it was only the "A" small bore stuff that used the circlips?
Crap..... GUDGEON pins, not rod bolts....
A+ have press fit GUDGEON pins..... :)
I agree, all the A+ 998 motors I've seen have the later slipper pistons. However, I used these and they didn't last. The earlier cir-clip fit pistons have lasted so far.
Irrelavent now of course.
Wil
andeh
Member #: 97
Near Daventry, midlands
i have an a+ 998 block sitting in my garage with a 1/2" grove down one of the bores. I beg to differ on the fact that they are all press fit. Block came from a circa 85 car, unsure on originality of the engine.
