Home > Help Needed / General Tech Chat > eBay lightweight battery
tomkidd
Member #: 1962
Lancaster
Look at this on eBay:
WESTFIELD CATERHAM 7 DAX LOCOST KIT CAR LIGHTWEIGHT 5.3KG RACING BATTERY MLR.NM
http://bit.ly/zR1Ixk
Anyone tried one? Seems light and cheap?
the 680 amps for 5 secs seems pretty crap to me, it's not a car battery that's for sure,
Nick
Member #: 154
Midlands
i've got about 3 of these sat in my garage, from wheelchairs. always been tempted to see if they''d be any good on a car but been a bit wary of them.
tomkidd
Member #: 1962
Lancaster
Seems that it's the same as the powervamp for cranking though http://www.ebay.co.uk/itm/PVR-25-race-gell...db#ht_720wt_922
We had one on the van. Did the job.
Got one in mine, sound as a pound?
Ive had one in mine for 2 years it was fine until my alternator stopped charging and it went flat. Fingers crossed it'll charge back up ok.
We flattened the vans a couple of times and it seemed to recover.
Ah thats good to know! Did you use a normal charger to charge it back up?
Halfords charger in standard mode. It did it twice and charged up fine.
tomkidd
Member #: 1962
Lancaster
Ok cool, I've bought one. I'll blame you set of bastards if it is shite *wink*
I've got one on my 1380, it does the job (just) but it does struggle. On a turbo I'd imagine it will be ok due to the lower compression.
Dr. jinG
Member #: 368
Roseville, CA (USA)
Why would you want to lighten up the rear? Seems to me that you'd be better off with a heavy battery in the boot, and spend your effort/cash making the front end lighter.
1967 Cooper 's' Turbo build @ www.drjing.com
carl talbot
Member #: 1323
If you want something really light , but more expensive [ theres always a trade off]
try these
http://www.ebay.co.uk/sch/burrenrig/m.html...=1&_from=&_ipg=
all the same size L 15 cm W 9 cm H 10.5 cm
YTX9 = 820 grams 9AH
YTX12 = 1kg 12AH
YTX14 = 1.1 kg 14AH
Edited by carl talbot on 28th Feb, 2012.
Ben H
Member #: 184
Melton Mowbray, Pie Country
It makes no difference. If you loose a couple of kg from the rear and then from the front it all balances.
http://www.twin-turbo.co.uk
I've shifted my diet battery onto the front inner wing.
i a little syspicious of any man who has a cream leather sofa,lol
try these
YTX12 = 1kg 12AH
YTX14 = 1.1 kg 14AH
My mam n dad do.
Edited by John on 28th Feb, 2012.
carl talbot
Member #: 1323
this is the man
http://www.uphillracers.com/showthread.php...-mini-5390.html
