Home > Help Needed / General Tech Chat > Alloy hubs advice
NickG
Member #: 7912
Australia oi oi oi!
HI lads
I bought some SC hubs but they have no screws holes tapped to hold the drums to the hub..
i was going to tap.. is it dangerous with no screws held to the hub? will it be ok? would you bother?
im scared maybe the hub could fall off or pop out?
my next Q what wont react with the hubs if i tap in a thread? stainless?
Don't worry about it. Your wheels will hold the drum in place.
NickG
Member #: 7912
Australia oi oi oi!
still seems risky ?
As above, the screw is pretty pointless.
kcchan
Member #: 8853
The drum won't come off until your wheel does and in that case, you've got bigger problems.....
Johnny
Member #: 6926
Accrington
when you tighten the wheel nuts it tightens onto the drum. the screw does nothing really.
Steve A
Member #: 7876
Walsall West Midlands WS1 2DW
I've got the same hubs, no problems, don't drill and tap them you could weaken the hubs, there is no need
Patina=old and knackered and won't clean up
Asphalt
Member #: 1027
Germini, black forrest
I've never had any drum that was so lose that it fell off once the wheel was removed. Which is the point of that screw I'd guess :)
My old Nissan didn't even have any securing screws on the front discs... :) But the discs couldn't fall off, as there was still the caliper hlding them in place...
[X] nail here for new monitor
The only thing the screw is really useful for is holding the drum on and square when you are adjusting the rear brakes. If you are that worried pop a hole in and tap it, and fit a countersunk screw.
As Tom points out; I'd got round this by temp fitting a couple of wheel nuts to clamp the drum and allow the brakes to be adjusted correctly without a wheel in the way.
Jason G
Member #: 1459
En-suite user
Braintree, Essex
I've always left them out. Mind, I generally destroyed a few that had corroded to the drum with knackered heads!
On 19th Jan, 2010 wil_h said:
Nick - They're no good for your car fella. Best thing you can do is wrap them up and post them to me *wink*
NickG
Member #: 7912
Australia oi oi oi!
haha.. Im going to tap in a TI bolt just one.
i know it's not needed, modern cars don't have this set up. but i like to have it.
ill just slap a shit load of anti seize shit on, thanks for the advice guys.
Edited by NickG on 28th Feb, 2012.
