Home > Help Needed / General Tech Chat > oil hose/fitting size
clubbie70
Member #: 8935
netherlands
i like to fit those goodridge aircraft style oil hoses and fittings.
Would it be better to use the dash8 (8mm)size fittings and hoses, or is the bigger dash 10 necessary??.
I'm afraid when using the 10mm , oilpressure could drop??!!
what are you guys using?
where are we talking about? from block to filter
clubbie70
Member #: 8935
netherlands
from block to filter house(remote) , then to cooler ( if necesarry), and then to block
-8 is not 8mm, -8 refers to the number of 1/16" the nominal thread size of the fitting is, so -8 = 8/16 = 1/2".
clubbie70
Member #: 8935
netherlands
ah..ok..sorry:).....but is -8 (1/2") enough??
when i measure the inside of a -8 ( the red part of fitting)i come at about 9mm and the -10 at about 11,5 mm
1/2 inch is probably over kill
minispares sell these
http://www.minispares.com/Product.aspx?ty=...id=34398&title=
my feed pipe is about 10mm od ( std steel one)
alexandre63
Member #: 9527
please can we help me I an going to do the same I whork as a palne mecanic and i can have some hose fitting what is the best 8AN ?
my engine is a 998 cooper some had a this type of linkage
anything will be better than the Banjo bolt.
I use 1/2" ID hose on mine, oil pressure isnt a problem
alexandre63
Member #: 9527
many thanks paul
joe i will think about this if I can have a banjo fitting
