| Home > Help Needed / General Tech Chat > Roll Cage tied to Front Subframe Mounts | |||||||
318 Posts Member #: 9408 Senior Member Tiptree, Essex |
27th Feb, 2012 at 10:12:15pm
Hi all, I have welded in a full cage, and as I'll be rallying this mini I'd quite like to tie the cage into the front subby mounts to stiffen it up a bit. Only real question is where exactly do people generally weld the front of the tubes to? The bulkhead has a gap between it and the tower bolts where they are boxed in through the front cross member, or with a spreader plate is that good enough?
www.topcatcustom.co.uk |
28th Feb, 2012 at 10:59:10pm
Nobody know anything about this? www.topcatcustom.co.uk |
28th Feb, 2012 at 11:02:02pm
I'd just tag it to the cross member where the subframe tower bolts go to.
28th Feb, 2012 at 11:13:57pm
Cheers, I guess with a spreader plate against the cross member it will be pretty good. I've wondered if those small tubes that run horizontally to pick up the lower mounts actually do anything at all, its about an inch tube over a metre long with pick ups on it's side, which doesn't seem to me like there would be any strength in it..? www.topcatcustom.co.uk |
![]() 412 Posts Member #: 9766 Senior Member Warwickshire |
29th Feb, 2012 at 12:31:56am
Mine goes through what was the air vent hole and next to the tower bolt
Avon 2010 class c 3rd
2 Posts Member #: 9834 Junior Member California |
4th Mar, 2012 at 12:53:31am
I've been lurking here long enough so I thought I'd finally join and answer this question. I asked the gentleman who installed my rollcage to do the same thing and here is what he came up with:
26th Mar, 2012 at 08:51:30am
Thought I'd just update this, I actually cut through the cross member right beside the tower bolts, passed the tubes right through and made them act as my front subframe tie bars too, should all be very stiff when finished, I will also tie in front shock mounts for if I use coilovers. Got to weld them all up yet but here's the basic idea.
27th Mar, 2012 at 11:38:16am
Nice but where is your rear seat/bulkhead?
On 5th Sep, 2011 Vegard said:
27th Mar, 2012 at 02:46:54pm
All been chopped out and cage is tied fully into rear turrets, shell etc, I think I'm going to replace it with ally bonded all the way round, it's so easy to work in the shell with no rear bulkhead!! www.topcatcustom.co.uk |
27th Mar, 2012 at 05:00:31pm
Looks like a nice tidy job.
28th Mar, 2012 at 08:38:35am
On 27th Mar, 2012 topcat said:
All been chopped out and cage is tied fully into rear turrets, shell etc, I think I'm going to replace it with ally bonded all the way round, it's so easy to work in the shell with no rear bulkhead!! No motorsport for you then - unlike bins this is one panel you cannot lose! On 5th Sep, 2011 Vegard said:
28th Mar, 2012 at 09:31:33am
Why not? SO long as the fuel tank is located out of the driver/passenger compartment (MSA words), it is fine, was originally going to fabricate a flat tank to sit inside/above the rear subframe and have the boot floor tubbed upwards to house it, keep the weight right down low and still legal, however I know it's not the original design, but I'm not intending on doing historic rallying with it. www.topcatcustom.co.uk |
29th Mar, 2012 at 09:07:04am
Need to read the blue book and section on taking out structural panels! Definitely in eligible for any sprinting - not sure about rallying. Certainly no go for racing. On 5th Sep, 2011 Vegard said:
31st Mar, 2012 at 07:41:03am
Is it classed as structural? I know it does provide a lot of stiffness but I have put in a hell of a lot more strength than I have taken out, and most other cars I see that come through the workshop have got aluminium rear bulkheads riveted and bonded in. It's not a big issue as can put it back in if need be, but would rather do it in ally or carbon. www.topcatcustom.co.uk |
1st Apr, 2012 at 04:41:17am
As soon as you start replacing structural parts with rollcage as opposed to simply uprating the shell you are into spaceframe territory and thus into sports libre. Fast Carl's best buddies the Deppers even have a shorter fibreglass front and part of the original wings. Some say this is so they can protest people with conventional removable front ends. But yes you need the original rear seat/bulkhead back in. I should add I sprinted Scruffy from 1989 to 2008 before I left the UK so have seen most things people have tried and failed at MSA wise. Edited by Scruffy on 1st Apr, 2012. On 5th Sep, 2011 Vegard said:
1st Apr, 2012 at 08:03:59pm
Thanks for the reply, most of the cars I looked in at the last rally I went to had carbon or ally main rear bulkhead panels, so can I assume this is ok so long as it is still sealed all the way round? I'd ideally like to put a steel edge in and rivet/bond carbon to it as a main panel. www.topcatcustom.co.uk |
2nd Apr, 2012 at 09:47:52am
Best thing to do is phone a scrutineer who does MSA log booking - you'll need one of these anyway and that way you'll know either way. On 5th Sep, 2011 Vegard said:
