| Home > General Chat > mini Innocenti Dash fitting and what to fit? | |||||||
![]() 825 Posts Member #: 2208 Post Whore Essex |
28th Feb, 2012 at 08:54:22pm
has anyone fitted a mini Innocenti Dash.
1713 Posts Member #: 8480 MS Paint flat cap champion & Morris Ital Lover From Sheffield now live in York tha noz |
28th Feb, 2012 at 09:07:27pm
I have that rev counter, its triumph fitment 4 cyl, found mine will only work direct from the mj ecu, the adaptor unit they sell is useless. I also have the matching mec speedo which was the same trigger fitting as a std cable and reads just a touch under true but there are a lot of identical smiths speedos with different fittings. Other options are to get a custom cable from people such as speedy cables who can also recalibrate any speedo to suit any application. I have used an etb electronic speedo, worked ok and easy to set up but seemed slow to respond, hope some of that helps. The inno dash is the nicest dash around IMO-im jealous
I am feeling particularly BACish today. On 5th Oct, 2014 Shauna said:
What that's crazy, you go commando hahaha! How heavy is your helmet ? The Morris Ital assassin! |
28th Feb, 2012 at 09:38:29pm
thanks for your help, i dont mind using the mj for the rev output.
On 28th Feb, 2012 oli79 said:
I have that rev counter, its triumph fitment 4 cyl, found mine will only work direct from the mj ecu, the adaptor unit they sell is useless. I also have the matching mec speedo which was the same trigger fitting as a std cable and reads just a touch under true but there are a lot of identical smiths speedos with different fittings. Other options are to get a custom cable from people such as speedy cables who can also recalibrate any speedo to suit any application. I have used an etb electronic speedo, worked ok and easy to set up but seemed slow to respond, hope some of that helps. The inno dash is the nicest dash around IMO-im jealous oli |
28th Feb, 2012 at 09:58:34pm
Buy a wideband before you spend all your cash on this!
Edited by theoneeyedlizard on 28th Feb, 2012. In the 13's at last!.. Just |
28th Feb, 2012 at 10:06:27pm
yeah yeah im on that as well!
On 28th Feb, 2012 theoneeyedlizard said:
But a wideband before you spend all your cash on this! |
