Home > Wanted > Minisport Straight Cut 1st gear
retroracer1380
Member #: 1972
Worcester
Bit of a longshot, im after a Minisport straight cut 1st gear, must be minisport type as others will not fit, i have given up with trying to get a new gear from Minisport after waiting about 7 months!
Oli
Edited by retroracer1380 on 1st Mar, 2012.
With minisport you will be waiting for ever *wink* and good luck with the gear
retroracer1380
Member #: 1972
Worcester
Yeh I know! Most useless mini company i have come across, hence why im looking for a used one
retroracer1380
Member #: 1972
Worcester
anyone?
Does it have to be minisport? When John broke second on the upside down skip's box, I had no idea what gearset we had. So I just bought an ST second gear with the right number of teath. Popped it in and away it went.
retroracer1380
Member #: 1972
Worcester
Yeh ive tried the minispares type and it wont fit even though it has the same tooth count, i bought it as a new gear kit from someone with no reverse or 1st gear, assuming it was a clubman gearset that used standard gears, i was wrong!
bugger...
