| Home > Help Needed / General Tech Chat > smoke on idle | |||||||
5 Posts Member #: 9828 Junior Member |
1st Mar, 2012 at 07:25:48pm
Hi
![]() 392 Posts Member #: 5702 Senior Member Cornwall |
1st Mar, 2012 at 07:29:51pm
What colour is the smoke?
1st Mar, 2012 at 07:31:34pm
What colour smoke?
1st Mar, 2012 at 08:06:19pm
the smoke is white, i had the guides and stems seals done last year. when i got the head back the valve's seemed to have a bit of play in them, side to side so i took it back they said it was normal but not 100% sure it is? i used the old valves but measured them 1st, they were all ok |
1st Mar, 2012 at 08:18:32pm
white is usually moisture in the smoke. check your head gasket is good. If it's a fresh build or one that has been apart for a bit it could have some moisture/oil left ot burn of. On 11th Feb, 2015 robert said:
1st Mar, 2012 at 08:35:40pm
white smoke could be alot of fuel Yes i moved to the darkside |
1st Mar, 2012 at 08:39:22pm
thanks for the advice! i'll let you know if i get to the bottom of it |
1st Mar, 2012 at 09:58:30pm
You could have smoke from the turbo out the exhaust side, which would mean no oil in the inlet.
In the 13's at last!.. Just |
1st Mar, 2012 at 10:15:39pm
What does black smoke on boost suggest? Audi s4 b5 - 470bhp & 486ft lbs
On 15th Mar, 2012 wil_h said:
1st Mar, 2012 at 10:20:14pm
very rich or fooked turbo Edited by Brett on 1st Mar, 2012. Yes i moved to the darkside |
1st Mar, 2012 at 10:23:02pm
Strange because my aem didn't say that, who knows lol Audi s4 b5 - 470bhp & 486ft lbs
1st Mar, 2012 at 10:25:08pm
rich misfire shows lean on the wideband no doubt it was your screaming t3 though Yes i moved to the darkside |
1226 Posts Member #: 9271 Post Whore Stoke on Trent |
1st Mar, 2012 at 10:30:05pm
my stem seals and/or guides have gone and mine starts with a big cloud of white'ish smoke but clears after 30 secs or so. doesnt help that i park it on a slight down bank as oil sits on the valves all night. one day boost will be mine!
On 10th Mar, 2012 Joe C said:
TBH peple stick it everywhere... and theres merits to each... |
2nd Mar, 2012 at 05:59:18am
I'm thinking it was the t3 too, there was no missing at all. Audi s4 b5 - 470bhp & 486ft lbs
2nd Mar, 2012 at 08:10:13am
White smoke can be a goosed turbo. Fastest 998 mini in the world? 13.05 1/4 mile 106mph
2nd Mar, 2012 at 05:33:45pm
On 1st Mar, 2012 bennyy said:
What does black smoke on boost suggest? it was your rings that shat themselves benny on number 3
2nd Mar, 2012 at 08:01:36pm
What does black smoke on boost suggest? it was your rings that shat themselves benny on number 3 that'll do it
2nd Mar, 2012 at 08:03:03pm
How did I forget about that lol cheers Steve. Audi s4 b5 - 470bhp & 486ft lbs
