Home > Help Needed / General Tech Chat > Verto or Pre-Verto?
Dr. jinG
Member #: 368
Roseville, CA (USA)
What are folks running, and why? I've got the Verto setup, but am considering swapping to Pre-Verto.
Thanks, all!
Pre-Verto0 Votes 0 Votes - 0%
Verto6 Votes 6 Votes - 0%
1967 Cooper 's' Turbo build @ www.drjing.com
Search for RTS clutch all will become clear. Alot of people that were running the pre-verto setup have now switched to a twin spring setup as they pretty much take everything you can throw at them and go easier on your thrusts. *wink*
EDIT: I was using a pre-verto with grey diaphragm, but it kept slipping so I made/fitted a twin spring verto and didn't even slip when it was coated in oil!
Edited by matty on 3rd Mar, 2012.
verto RTS
bennyy
Member #: 9037
Doncaster, yorkshire
Verto RTS, search for clutch thoughts
On 15th Mar, 2012 wil_h said:
On 30th Apr, 2012 Brett said:
Verto RTS with turbo and std 1275 springs, 190mm organic plate and MED ultralite flywheel.
200 bananas no problem on mine. It'll take more.
verto
minivan63
Member #: 9645
South Wales
I'm going to use a verto, but just with an uprated cover as I'm only building a 998. Mainly for the reasons Matt said about the thrust bearings.
Edited by minivan63 on 3rd Mar, 2012.
1293 sprite
Member #: 5449
Melton Mowbray
Does anyone sell ready made RTS clutches or is it a diy only thing?
1293 88.8hp 82.2ftlb
17.3 1/4 @ 78 mph
Naturally Aspirated (for now)
Sprocket will make you one if you supply him the bits.
wez
Member #: 9271
Stoke on Trent
details on page 3 of this thread
http://www.turbominis.co.uk/forums/index.p...id=444733&fr=50
one day boost will be mine!
